Старый 15.12.2009, 23:05   #1
paruvella: Displaying the employee images on the EP pages of Dynamics Ax
Источник: http://paruvella.spaces.live.com/Blo...4DB0!378.entry
In this example I am going to illustrate, displaying the employee images on EP pages.
Note: Assumed that all the images(photos) are mapped to their employee records by using Employee Details form in Ax client.
After the images are mapped to employee records, need to Publish the images in to sharepoint path by selecting the Publish images form, from Administartion à Setup àInternet àEnterprise Portal àPublish images  as shown in below figure and click on the Publish button of the form.
In this example, I am going to filter the records from Employee table, which employee is mapped to current user (logged in Ax user).
Development Steps
Step – I:
Prepare the Dataset for this example application by using the EmplTable and CompanyImage tables as shown in below figure.
Step – II:
Override the executeQuery method on the EmplTable of the above dataset.
This method for filtering the employee records from employee table, which employee is mapped to current user.
public void executeQuery()
    Query                   query = new Query();
    QueryBuildDataSource    qbs, qbs1;
    QueryBuildRange         qbr;
    QueryRun                qr;
    qbs = query.addDataSource(tablenum(EmplTable));
    qbs1 = qbs.addDataSource(tablenum(SysCompanyUserInfo));
    qbs1.addLink(fieldnum(EmplTable, EmplId), fieldnum(SysCompanyUserInfo, EmplId));
    qbr = qbs1.addRange(fieldnum(SysCompanyUserInfo, UserId));
    qbr.value(curuserId());
    qbr.status(RangeStatus::Hidden);
    qbs1.joinMode(joinmode::ExistsJoin);
    this.query(query);
    super();
Override the executeQuerymethod On the CompanyImage table of the above dataset.
The following method is used for filtering the Employee image(photo) from CompanyImage Table
    Query                   q;
    QueryBuildDataSource    qB;
    q = new Query();
    qB = q.addDataSource(tablenum(CompanyImage));
    qbr = qB.addRange(fieldnum(CompanyImage,RefCompanyId));
    qbr.value(queryValue(emplTable.company()));
    qbr = qB.addRange(fieldnum(CompanyImage,RefTableId));
    qbr.value(queryValue(emplTable.TableId));
    qbr = qB.addRange(fieldnum(CompanyImage,RefRecId));
    qbr.value(queryValue(emplTable.RecId));
    this.query(q);
    super();
Step – III:
Developing the required webpart for displaying the employee information and his image.
Markup Code for the UserEmployeeInfo webpart
</span>
C# (Code behind)Code for the UserEmployeeInfo webpart
using System;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using Microsoft.Dynamics.Framework.Portal.UI.WebControls;
using Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts;
using Microsoft.Dynamics.Framework.Data.Ax;
using Microsoft.Dynamics.Framework.Metadata.Ax;
using Proxy = Microsoft.Dynamics.Framework.BusinessConnector.Proxy;
using ApplicationProxy = Microsoft.Dynamics.Portal.Application.Proxy;
using Microsoft.Dynamics.Framework.BusinessConnector.Session;
using Microsoft.Dynamics.Framework.BusinessConnector.Adapter;
public partial class UserEmploeeInfo : System.Web.UI.UserControl
    #region Properties...
    /// Returns the current webpart
    private AxBaseWebPart WebPart
        get { return AxBaseWebPart.GetWebpart(this); }
    /// Returns the current webpart session
    private ISession AxSession
        get
            AxBaseWebPart webpart = AxBaseWebPart.GetWebpart(this);
            return webpart == null ? null : webpart.Session;
    //Enterprise portal images folder path
    string EPLayoutImagesPath
        get { return "/_layouts/ep/images/"; }
//reading the imagepath of the employee record from sharepoint
string GetImagePath(IAxaptaRecordAdapter record)
        return this.EPLayoutImagesPath + ApplicationProxy.EPWebSiteParameters.companyImageFileName(AxSession.AxaptaAdapter, record);
    #endregion
    protected void Page_Load(object sender, EventArgs e)
        if (!this.IsPostBack)
            IAxaptaRecordAdapter row = UserEmployeeInfo.GetDataSourceView("CompanyImage").DataSetView.GetCurrent().GetRecord();
            imgCompany.ImageUrl = this.GetImagePath(row);
Step – IV:
Add this newly developed user control to AOT and deploy this webpart on the sharepoint page. Open the newly created page url in the explorer and observe the result as follows.
This is how employee images will be displayed on the EP pages of Dynamics Ax.  ......
emeadaxsupport: The Dynamics AX Client sometimes terminates when displaying certain HTML pages in a Web browser control Blog bot DAX Blogs 0 15.10.2009 15:05
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 17:03.
