Старый 22.01.2010, 15:05   #1
25,643 / 848 (80) +++++++
palleagermark: Convert an image from one format to another from AX
Источник: http://palleagermark.blogspot.com/20...format-to.html
Here's is how you can convert an image from one format to another:
static void Job5(Args _args)
System.Drawing.Image image;
image = System.Drawing.Image::FromFile(@"C:\sandbox\test.tif");
image.Save(@"C:\sandbox\newtest.jpg", System.Drawing.Imaging.ImageFormat::get_Jpeg());
The new files tend to be a bit larger. You have to work with the ImageCodecInfo class from .NET to fix this.
palleagermark: Create a 64-bit encoded string from an image in AX Blog bot DAX Blogs 0 22.01.2010 15:05
mfp: New X++ Editor Blog bot DAX Blogs 2 06.01.2010 02:06
palleagermark: Creating an image file based on plain text from AX Blog bot DAX Blogs 0 03.03.2009 03:08
palleagermark: Channel 9 video: Dynamics AX Version Control interview from Convergence in Copenhagen 2008 Blog bot DAX Blogs 0 30.01.2009 16:05
Часовой пояс GMT +3, время: 00:38.
