#1 |
emeadaxsupport: Some charts in the Role Center show a wrong axis scale 0-0-0-1-1-1
Источник: http://blogs.msdn.com/b/emeadaxsuppo...0-0-1-1-1.aspx
============== We recently came across an issue, that if you are using Microsoft SQL Server 2008 Reporting Services some charts in the Microsoft Dynamics AX 2009 Role Center have incorrect axis scale values on the Y-Axis. Instead of values from e. g. 0 to 1000 you only see 0-0-0-1-1-1. For example the following chart reports are showing an incorrect Y-Axis scale: Report Library Report Cust CashIflowvsCashOutflow CashReceiptJournalTotalsTrxCount ExpectedCashNextDays PostedCustomerInvoiceTotalsandTrxCnt Ledger ActualvsBudget GrossProfitinthePastXPeriods SalesInPastXMonths TotalAccountPayablePastXPeriods TotalAccountsReceivablePastXPriods TotalExpensesByPeriod Vend PurchasesPastXPeriods VendorInvoiceJournalTotalTrxCount VendorPaymentJournalTotalTrxCountThis issue does not exist if you are using Microsoft SQL Server 2005 Reporting Services. The problem is caused by the report design of the affected chart reports. More concrete the Max Value property of the Y-Axis is having the value 1E-06 set which is wrong. Changing the property to 0 (which means Auto) and re-deploying the Report Libraries resolves the issue. In order to change the Max Value property please follow these steps:
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
