Старый 04.06.2010, 21:06   #1
25,643 / 848 (80) +++++++
emeadaxsupport: Workflow error. Cannot resolve Workflow originator when user language is not English
Источник: http://blogs.msdn.com/b/emeadaxsuppo...t-english.aspx
Some time ago we run into this problem for user whose language was Spanish although I can also happen for other users with different languages (i.e. Polish).
When we configure the workflow assignment as “assign to:” to be “Role Based” and we choose “Workflow originator” The workflow task is never assigned to any user and a “Host Runtime ” error is logged on the event log.
Dynamics Adapter CallStaticClassMethod failed..
And in Workflow history form you can find error
"User group could not be found"
in local language (label @SYS105452)
The issue happens in class SysWorkflowProviderService method resolveParticipant in mentioned if:
// handle actor paricipants if (strcmp(enum2str(WorkflowActorType::Originator), _participant) == 0)
    users = WorkflowUserList::construct();
    users.add(workflowTable.Originator);
The problem here is that in Spanish
enum2str(WorkflowActorType::Originator) = Orginador del flujo de trabajo (@Sys102950)
_participant =Orginador del flujo
So the  strcmp (string compare) returns value false and user is not added. The parameter _participant is cut to 20 signs, the reason behind is that it is Extended Data Type WorkflowParticipantToken::Orginator which string size is setup to 20.
There can be two solutions:
1. Change property StringSize of WorkflowParticipant token to 40.
2. Create new label which length will be shorter than 20 and assign it to WorkflowParticipantToken::Orginator
emeadaxsupport: Error message “The value ‘xxx’ is not found in the map” when opening Workflow configuration Blog bot DAX Blogs 0 10.02.2010 00:07
emeadaxsupport: Workflow - user abc has no access to menu item PurchReqTable Blog bot DAX Blogs 0 28.10.2009 00:06
emeadaxsupport: Certain User groups cannot be deleted in Dynamics AX Blog bot DAX Blogs 0 29.07.2009 19:05
Часовой пояс GMT +3, время: 20:32.
