Старый 16.06.2010, 10:05   #1
East Ocean - Technical: SQL divide by zero "isZero" function
Источник: http://eastoceantechnical.blogspot.c...-function.html
Recently come across a requirement on SQL to divide 2 columns and populate in a custom fields. Infact is just something simple like "SELECT column1/column2 AS result"
Issue raised because the "column2" might contains zero or null value, what we need to do is if column 2 is zero replace it with another fix non zero varible.
  • Null issue can be easily solve by using isNull finction, but we don't have 'isZero' function
The solution is to use the nullif function with isnull function;
set column2 to null value if it is zero, outer level if is null replace with variable X.
ISNULL(NULLIF(column2, 0),variableX)
East Ocean - Technical: CRM 5.0 & Azure Blog bot Dynamics CRM: Blogs 0 10.01.2010 19:07
East Ocean - Technical: CRM 4.0 Update Rollup 8 Blog bot Dynamics CRM: Blogs 1 21.12.2009 20:51
East Ocean - Technical: CRM 4 - Small changes:big effect Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
East Ocean - Technical: Maximum attributes supported by CRM 4! Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 21:21.
