Старый 23.07.2010, 07:12   #1
Dynamics AX Sustained Engineering: Issue in Vendor payment history when posting multiple vendor transactions on the same voucher
Источник: http://blogs.technet.com/b/dynamicsa...e-voucher.aspx
Scenario:
When posting multiple vendor transactions on the same voucher the Vendor payment history inquiry may not appear as expected.
Resolution:
To resolve the issue the following change can be made to \Forms\VendorPaymentHistory\Data Sources\VendInvoiceJour\Methods\initQueryforEPandCheckInvoices
select firstonly VendTransId from ledgJourTrans
where ledgJourTrans.Voucher ==_lastSettleVoucher
&& ledgJourTrans.VendTransId;
To:
&& ledgJourTrans.AccountNum == vendAccount
Dynamics AX Sustained Engineering: How to prevent transaction reversal from posting to closed dimensions Blog bot DAX Blogs 0 22.04.2010 23:05
Dynamics AX Sustained Engineering: Incorrect posting profile used when cancelling a prepayment Blog bot DAX Blogs 0 09.12.2009 09:05
Dynamics AX Sustained Engineering: Performance issue in "Open Transaction Edit" form Blog bot DAX Blogs 0 26.10.2009 20:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 15:05.
