Старый 28.09.2010, 10:05   #1
25,643 / 848 (80) +++++++
Khue Trinh: Fill Utility in AX2009
Источник: http://khuetrinh.wordpress.com/2009/...ity-in-ax2009/
If you are using AX2009, you may want to explore a new feature called Fill Utility. This functionality allows you to update a range of records with a value. Basically, I found that this works like using UPDATE T-SQL statement … Continue reading →
Dynamics AX Sustained Engineering: Fill Utility incorrectly updating a field in a form datasource Blog bot DAX Blogs 1 27.05.2010 23:05
Khue Trinh: Fill Utility in AX2009 Blog bot DAX Blogs 0 10.07.2009 10:05
Khue Trinh: Mass Deployment of the Microsoft Dynamics AX Client Blog bot DAX Blogs 0 07.01.2008 15:51
Khue Trinh: Be careful with Inventory journal Blog bot DAX Blogs 0 07.01.2008 15:51
Часовой пояс GMT +3, время: 12:58.
