Старый 14.10.2010, 17:05   #1
gustafwesterlund: Publishing reports for external use
Источник: http://gustafwesterlund.blogspot.com...ernal-use.html
Recently I have been working quite a lot with reports and I must say that the new GUI in Reportdesigner for SQL RS 2008 is really a nice facelift.
I have been working with autogenerating reports as PDF:s as I have previously blogged about. It is a bit more complex to do in SQL Server 2005 and later since you have to work with two webservices that have similar class names, which I must say is a real stroke of genius. If there is interest, I might be looking into writing some about this.
An interesting thing I noticed about this is that despite the fact that the report previously has been published for external use, each update of the report will require you to republish it in order for the changes to stick. You can otherwise get some really interesting inconsistencies.
Gustaf Westerlund
CEO, Chief Architect and co-Founder at CRM-konsulterna AB
www.crmkonsulterna.se
axStart: Please keep the AOT reports in Dynamics AX next release alive Blog bot DAX Blogs 0 09.06.2010 08:05
axStart: Please keep the AOT reports in Dynamics AX next release alive Blog bot DAX Blogs 2 13.12.2008 12:18
Microsoft Dynamics CRM Team Blog: Use Shared Data Source for custom Microsoft Dynamics CRM reports Blog bot Dynamics CRM: Blogs 0 05.12.2008 00:05
Microsoft Dynamics CRM Team Blog: Categorizing and Displaying Reports in Different Languages Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 11:35.
