Старый 09.11.2010, 19:10   #1
Dynamics Ax: Publish Selected Fields using AIF without Send Framework
Источник: http://axblog4u.wordpress.com/2010/1...end-framework/
Sample example is written for publishing selected field based on AIF setup made in Data-policies form without using AxdSend framework class. /// <summary> /// The <c>LedgerTableRead</c> job will published the xML to the folder /// mentioned in channel path. /// Note: Once the job is executed sucessfully please run the AIF job /// to push [...]
Часовой пояс GMT +3, время: 00:14.
