Старый 14.12.2010, 10:11   #1
dax-lessons: Generate XML Documentation Files for a project – DAX 2009
Источник: http://dynamicsaxgyan.wordpress.com/...ject-dax-2009/
To generate XML documentation files for a project Open the Projects form by pressing CTRL+SHIFT+P. Right-click the project for which you want to create XML documentation files, point to Add-Ins, and then click Extract XML documentation. Select the Documentation check … Continue reading →
dax-ideas: Reading an XML file in AX 2009 Blog bot DAX Blogs 0 16.11.2010 22:11
Microsoft DAX Dev Center Headlines: AX 2009 Documentation White Paper Released Blog bot DAX Blogs 0 14.11.2009 03:10
chrisfie: Microsoft Dynamics AX 2009 and Microsoft Project Server 2007 Demo Image Blog bot DAX Blogs 2 03.07.2009 20:05
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
dax-lessons: Generate XML Documentation Files for a project - DAX 2009 Blog bot DAX Blogs 0 08.08.2008 19:06
Часовой пояс GMT +3, время: 05:46.
