Старый 17.12.2010, 00:12   #1
Jose Lorenzo: Calendars and the change dates utility
Источник: http://blogs.msdn.com/b/jlorenzo/arc...s-utility.aspx
My college Sue, in New Zealand, made a very good observation on relation to the Change date utility of the previous post Demo data utilities – Dynamics AX 2009. If you don’t go forward in an exact 7 day increment/decrement, you might need to rebuild your calendars because by instance your Sat/Sun can becomes Sun/Mon etc. …
Rebuilding the calendars is a very simple process.
If you need, for some particular reason, move the dates on a number of days different to multiples of 7 you can follow this simple instructions to rebuilt your calendars:
 Rebuilding calendars working times - Dynamics AX 2009
I added a warning (when not entering multiple of seven days) to the utility itself to advise on this.
Часовой пояс GMT +3, время: 22:09.
