Старый 20.12.2010, 22:11   #1
25,643 / 848 (80) +++++++
emeadaxsupport: Printer name is invalid error when printing a report
Источник: http://blogs.msdn.com/b/emeadaxsuppo...-a-report.aspx
We came across an issue where we got the following error when trying to open or print a report:
OpenPrinter_1: rc:0 lastError:1801(0x709) The printer name is invalid.
The printer was installed on the domain server and when checking the printer name we could verify that the printer name doesn't include illegal characters as "\" or ",".
Finally we could find out that the printer was not not visible as resource in the Active Directory.
On properties for the printer it was necessary to select "List in directory" in order for AX to see the printer.
author: Anders Madsen editor: Daniel Durrer date: 20/Dec/2010
Старый 17.01.2017, 12:14   #2
mnt_dx is offline
mnt_dx
Axapta Retail User
1,747 / 165 (9) ++++++
Коллеги, пользователь получает ровно такую же ошибку, вернее даже в индолог выводится от 3 до 10 строк с такой ошибкой.
Вопрос: как понять, на какой принтер ругается АХ, чтобы с ним проделать настройку из рекомендации?
emeadaxsupport: Proxy settings can interfere Dynamics AX 2009 report deployment Blog bot DAX Blogs 0 20.01.2010 15:05
emeadaxsupport: Visual Studio Dynamics AX report development how to associate X++ class with report dataSet Blog bot DAX Blogs 0 13.01.2010 23:08
Microsoft Dynamics CRM Team Blog: Auditing Report Execution using the ReportServer Database Blog bot Dynamics CRM: Blogs 0 19.11.2008 20:05
gatesasbait: Report 'shape' control issues with PDF Printer class in Dynamics AX 4.0 Blog bot DAX Blogs 0 09.09.2008 07:07
Часовой пояс GMT +3, время: 00:45.
