Старый 17.03.2011, 18:04   #1
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Post Microsoft Dynamics AX Connector for SAP
Cлайд №6 в презентации ukax: Microsoft Dynamics AX March Roadshow Deck
Partnersource: Microsoft Dynamics Two-Tier ERP Strategy
News
The Microsoft Dynamics AX Two-Tier connector for SAP enables common business process integration scenarios for headquarters and subsidiary locations, including the following:
  • Financial consolidation: consolidation of financial information from subsidiaries using Microsoft Dynamics AX can be exposed through a central SAP installation, increasing visibility of financial performance across the organization.
  • Regional distribution: integration of intercompany procurement and supply-chain processes between local and regional distribution with centralized fulfillment organizations helps facilitate automated order processing.
  • Regional sourcing / manufacturing: integration of decentralized manufacturing operation or procurement processes into centrally orchestrated planning processes enables more accurate and responsive manufacturing planning or procurement across the organization.
The following materials will give you a full understanding of the connector from a functional and technical perspective.
The Microsoft Dynamics AX two-tier connector is composed of products that help partners and customers to connect Microsoft Dynamics AX to SAP ERP through BizTalk Server.
Microsoft Dynamics AX Two-Tier Connector FAQ
Find answers to commonly asked questions about the Microsoft Dynamics two-tier strategy and Microsoft Dynamics AX Connector for SAP.
Microsoft Dynamics AX Connector for SAP Product Download
The connector includes only rights to use the Two-Tier Connector only. The connector does not include any other usage rights. Microsoft Dynamics AX users accessing directly or indirectly to the Microsoft Dynamics AX solution should be licensed according to BRL Licensing Terms and Conditions (Software License Terms and the Dynamics ERP Licensing Guidelines)
The connector is requiring other technologies such as BizTalk Server as well as Microsoft Dynamics AX and SAP adapters that are required to be acquired/licensed separately
Customers should also make sure that they have the adequate SAP licenses required to operate using the connector
Please refer to the implementation white papers to understand how the Microsoft Dynamics AX Two-Tier Connector for SAP works.
Microsoft Dynamics AX connector product download:
Download and install the Microsoft Dynamics AX .xpo file that is required to implement the Microsoft Dynamics AX Two-Tier Connector for SAP.
Microsoft BizTalk Server connector product download:
Download and install the .BizTalk Server msi file that is required to implement the integration orchestration scenario for the Microsoft Dynamics AX Two-Tier Connector for SAP.
You can find additional information about Microsoft Dynamics ERP Two-Tier Strategy here.
Presentation
Two-Tier ERP - Optimal balance between business agility and IT efficiency
This deck was created for EMEA Convergence 2010. Partners can use the deck in their engagements with prospects and customers.
Доп. информация:
http://www.microsoft.com/en-us/dynam...-two-tier.aspx
Последний раз редактировалось Poleax; 18.03.2011 в 09:33.
За это сообщение автора поблагодарили: konopello (3), Innokentiy (1).
biztalk, sap
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 21:51.
