Старый 30.03.2011, 18:11   #1
waikeatng: Using RunBaseBatchPrintable class
Источник: http://waikeatng.blogspot.com/2010/1...ble-class.html
RunBase framework is used when we develop a class to run an operation within Dynamics AX, such as posting a sales order or used in any data manipulation operation. If we need to batch the operation, we will commonly use the RunBaseBatch framework by extending the RunBaseBatch class.
Dialog for a class that extends RunBaseBatch
The RunBaseBatch class does not provide the access to printer such as when running a report. If you need to provide the printer support to allow users to specify the printer options in the operation, you can extend the RunBaseBatchPrintable class instead of RunBasebatch class.
Dialog for a class that extends RunBaseBatchPrintable
When extending the RunBaseBatch class, you need to override the pack() and unpack() methods. If query is used in the operation, you may need to also override the initParmDefault(), queryRun(), and showQueryValues() methods.
When extending the RunBaseBatchPrintable class, in addition to the above methods, you would also need to make the following amendments:-
1) Modify the pack() to serialise the printJobSettings object (inherits from RunBaseBatchPrintable class)
public container pack()
    return [#CurrentVersion,
            #CurrentList,
            queryRun.pack(),
            printJobSettings.packPrintJobSettings()  // Serialise the printJobSettings object
2) Modify the unpack() to deserialise the printJobSettings object
public boolean unpack(container _packedClass)
    Version         version = RunBase::getVersion(_packedClass);
    container       packedQuery;
    container       packedPrintJobSettings;
    switch (version)
        case #CurrentVersion:
            [version, #CurrentList, packedQuery, packedPrintJobSettings] = _packedClass;
            if (packedQuery)
                queryRun = new QueryRun(packedQuery);
            // Deserialise the printJobSettings object
            if (isSwappedFromServer)
                printJobSettings = SysPrintOptions::newPrintJobSettingsOnServer(packedPrintJobSettings);
            else
                printJobSettings = new PrintJobSettings(packedPrintJobSettings);
            break;
        default:
            return false;
    return true;
3) To retrieve the user-selected printer settings, you can use the printJobSettings variable directly in the code. For example:-
public void run()
    info(strfmt('Selected printer is %1', printJobSettings.printerPrinterName()));
    // pass the printJobSettings object to run a report based on the selected printer settings
    reportRun = classFactory.reportRunClass(args);
    reportRun.init();
    reportRun.printJobSettings(printJobSettings.packPrintJobSettings());
    reportRun.run();
Happy DAXing!!
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 31.03.2009 06:06
Kashperuk Ivan: List panels in Dynaics AX - a short description of SysListPanel class Blog bot DAX Blogs 1 21.10.2007 22:51
Kashperuk Ivan: Description of ClassBuild class:Today I want to ... Blog bot DAX Blogs 0 26.01.2007 05:51
Axapta Lessons: Exporting Tables and Class definitions Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 02:15.
