Старый 22.04.2011, 17:11   #1
25,643 / 848 (80) +++++++
equalized: Dynamics Ax printing logo’s from batch
Источник: http://blog.equalized.be/2011/01/dyn...os-from-batch/
Hi,
As all of you know the Image class in Dynamics Ax 4.0 and 2009 can only run on client. This poses a problem when you want to print for example invoices with your company logo on it. Having this found out I went to look for an alternative!
I’ve added this code to the top of the PDFViewer class in the writeBitmap(OutputBitmapField _field, OuputSection _section) method
if( isRunningOnServer() &&
    _field.name()       == #FieldLogo)
    this.BLOGWriteBitmapOnServer(_field,_section);
    super(_field, _section);
    return;
For the method BLOGWriteBitmapOnServer(OutputBitmapField _field, OuputSection _section) I have copied everything from the writeBitmap and started by replacing the Image object with a System.Drawing.Image object, you can make a company parameter for this file path.
img = System.Drawing.Image::FromFile(imgStr);
After compiling there are a few errors witch I’ve corrected and ended up with this code.
public void BLOGWriteBitmapOnServer(OutputBitmapField _field, OuputSection _section)
    #File
    BinData bin = new BinData();
    //Image img;
    container data, imgInfoData;
    str s;
    real x1,x2, y1,y2;
    Struct br;
    int imageObjectNo = 0;
    int newwidth, newheight;
    real pdfPreviewScale = 0.8;
    boolean generateXImage = false;
    container c;
    str fn;
    FileIOPermission writePermission;
    FileIOPermission readPermission;
    boolean grayScale = false;
    System.Drawing.Image    img;
    str                     imgStr;
    int                     widthTemp, heightTemp;
    CompanyInfo             companyInfo = companyInfo::find();
    new InteropPermission(InteropKind::ClrInterop).assert();
    imgStr  = companyInfo.BLOGCompanyLogoFile;
    br = this.boundingRectTwips(currentPage, _section, _field);
    x1 = br.value('x1'); y1 = br.value('y1');
    x2 = br.value('x2'); y2 = br.value('y2');
    if (_field.type() == 10) // resourceId, DB_RESId
        //img = new Image(_field.resourceId());
        if (resourceIdImageMap.exists(_field.resourceId()))
            imageObjectNo = resourceIdImageMap.lookup(_field.resourceId());
        else
            imageObjectNo = this.nextObjectNo();
            resourceIdImageMap.insert(_field.resourceId(), imageObjectNo);
            generateXImage = true;
        if (debugLevel >= 1)
            info ('Image in resource ' + int2str(_field.resourceId()));
    else if (_field.type() == 7) // queue
        c = _field.value();
        if (c)
            //img = new Image(c);
            if (img)
                info ('Image in container');
            else
                info ('No image in container');
    else // string containing filename
        //img = new Image(_field.imageFileName());
        if (stringImageMap.exists(_field.imageFileName()))
            imageObjectNo = stringImageMap.lookup(_field.imageFileName());
        else
            stringImageMap.insert(_field.imageFileName(), imageObjectNo);
            info ('File is ' + _field.imageFileName());
    if (img)
        if (generateXImage)
            fn  = System.IO.Path::GetTempFileName();
            widthTemp   = img.get_Width();
            heightTemp  = img.get_Height();
            img.Save(fn);
            // revert previous assertion
            // assert read permissions
            readPermission = new FileIOPermission(fn, #io_read);
            readPermission.assert();
            // BP deviation documented (note that the file io assert IS included above)
            bin.loadFile(fn);
            data = bin.getData();
            // Get rid of the temporary file.
            //WinAPIServer::deleteFile(fn);
            System.IO.File::Delete(fn);
            if (bitmapEncode85)
                s = bin.ascii85Encode();
            else
                s = BinData::dataToString(data);
            objectOffsetMap.insert(imageObjectNo, binBuffer.size());
            this.appendTextToBuffer(int2str(imageObjectNo) + ' 0 obj <<\n');
            if (grayScale)
                this.appendTextToBuffer('  /Type/XObject /Subtype/Image /ColorSpace /DeviceGray\n');
            else
                this.appendTextToBuffer('  /Type/XObject /Subtype/Image /ColorSpace /DeviceRGB\n');
            this.appendTextToBuffer('  /Name /I' + int2str(imageObjectNo) + ' /BitsPerComponent 8\n');
            if (!bitmapEncode85)
                this.appendTextToBuffer('  /Filter [/ASCIIHexDecode/DCTDecode] /DecodeParms[null<<>>]\n');
                this.appendTextToBuffer(strfmt('  /Length %1\n', strlen(s)+1));    // Allow for end of data marker
            else
                this.appendTextToBuffer('  /Filter [/ASCII85Decode/DCTDecode] /DecodeParms[null<<>>]\n');
                this.appendTextToBuffer(strfmt('  /Length %1\n', strlen(s)));
            // Specify dimensions via newwidth/newheight.
            this.appendTextToBuffer(strfmt('  /Width %1 /Height %2\n', widthTemp, heightTemp));
            this.appendTextToBuffer('>>\nstream\n');
            this.appendTextToBuffer(s);
                this.appendTextToBuffer('>'); // End of Data marker
            this.appendTextToBuffer('\nendstream\nendobj\n');
        // Have to put imageObjectNo or it will be only on page #1
        imagesOnPage.add(imageObjectNo);
        // Generate the object that draws the image...
        s  = 'q\n';
        s += this.drawFieldFrame(_field, x1, y1, x2, y2);
        // Provide a scaling factor bringing the image size up to the size requested by the report
        // Also, provide x,y pos)
        if (_field.resize())
            s += '   ' + this.real2str(x2-x1) + ' 0 0 ' + this.real2str(y2-y1) + ' ' + this.real2str(x1) + ' ' + this.real2str(y1) + ' cm\n';
        else
            //We should resize the bitmap according to the area given in PDF page otherwise there will be out of area drawing
            //The PDF bitmap drawing has wrong scaling from what we see in the preview so we should also scale it by PDFPreviewScale
            newwidth = min(abs(x2-x1)/pdfPreviewScale, widthTemp);
            newheight = min(abs(y2-y1)/pdfPreviewScale, heightTemp);
            x1 += this.twips(this.borderWidth(_field.borderWidth(), _field.lineLeft()));
            y1 += this.twips(this.borderWidth(_field.borderWidth(), _field.lineRight()));
            x2 -= this.twips(this.borderWidth(_field.borderWidth(), _field.lineTop()));
            y2 -= this.twips(this.borderWidth(_field.borderWidth(), _field.lineBottom()));
            if (_field.alignment() == Alignment::Center)
                x1 = (x1 + x2 - newwidth) / 2;
                y1 = (y1 + y2 - newheight) / 2;
            else if (_field.alignment() == Alignment::Right)
                x1 = x2 - newwidth;
                y1 = y2 - newheight;
            else    // left
            s += '   ' + this.real2str(newwidth) + ' 0 0 ' + this.real2str(newheight) + ' ' + this.real2str(x1) + ' ' + this.real2str(y1) + ' cm\n';
        s += '   /I' + int2str(imageObjectNo) + ' Do\n';
        s += 'Q\n';
        this.appendTextToPage(s);
This could probably been done much cleaner, but it does the job.
Последний раз редактировалось Poleax; 22.04.2011 в 17:25. Причина: код
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 15:28.
