Старый 04.05.2011, 21:13   #1
Rahul Sharma: Install Microsoft Dynamics AX 2009 SP1 on Windows 7
Источник: http://feedproxy.google.com/~r/Rahul...-2009-sp1.html
Many of us use VPC for AX demo and exploration because it has all the required components already in place. But it requires you to have enough memory to run your host OS and VPC at the same time, it also slows down your system. If you don’t have enough free memory then it will even refuse to load.
This article is for those who want to install AX on their laptop, so that they don’t have to wait for VPC to start (or wake up from hibernation) and at the same time want to maintain the system performance at its best.
Here are the steps to install local AX 2009 SP1 on your laptop running Windows 7 OS.
Dynamics AX Basic Installation:
  • Make sure you are logged in through your domain account (domain\user) on your laptop, not local system account.
  • You should have local admin rights on your laptop.
  • Install SQL Server 2008 with SP1. Service account for this should be local system.
  • Install AX 2009. You need to be connected to your domain while installing AX. Ignore warning that says this operating system is not supported.
  • AOS again should run under local system, instead of your domain account. Because this way you can use AX when you are out of your domain network.
    Hint: At the time of installation select Network service and after successful installation convert AOS service account to Local System.
  • On the next screen, uncheck checkbox which says start AOS after installation.
  • Click Install and you are done with the basic AX 2009 installation.
  • To get it running with SQL Server 2008 SP1, you need AX 2009 SP1.
  • Install AX 2009 SP1.
  • Start AOS. (Optional: you may need to change the AOS service account to Local System).
  • In AX, AdministratorSetupSecuritySystem service account, Set BC Proxy Account to your domain account (user , domain.com).
  • Import Demo Data.
Dynamics AX Role Center & Enterprise Portal Installation:
  • EP needs Sharepoint portal to be installed on your laptop. To install WSS / MOSS on your Windows 7 OS follow this link. Install Sharepoint on Windows 7.
  • Once you have installed & configured Sharepoint, install Role center & Enterprise portal from the AX installation CD. It will run fine; I have checked it on my laptop.
  • If you have Visual Studio 2008 installed, then you can also install enterprise portal development tools.
Dynamics AX Workflow:
  • Just install this component, it will also be installed without error. Just ignore any warning you see.
Dynamics AX SQL Reporting Services:
  • You can deploy reports to your reporting server without any error. Make sure SSRS service account is local system.
  • I am having some difficulty running AX SSRS reports. I will update you all once this part is also done.
I hope this helps someone.
Join me on facebook and feel free to post your comments / feedback / queries.
www.RahulSharma.in
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
chrisfie: Microsoft Dynamics AX 2009 and Microsoft Project Server 2007 Demo Image Blog bot DAX Blogs 2 03.07.2009 20:05
AX UK: Microsoft Dynamics AX 2009 Exam Deadline extended to 1st July 2009 Blog bot DAX Blogs 0 03.12.2008 19:05
JOPX: Why Microsoft Dynamics AX 2009 might interest SharePoint developers ... Blog bot DAX Blogs 0 21.08.2008 01:05
Часовой пояс GMT +3, время: 01:11.
