Старый 11.05.2011, 06:15   #1
X++: Working with System.Char in X++
Источник: http://blogs.msdn.com/b/x/archive/20...char-in-x.aspx
There are situations where it is useful to workl with characters in X++. As you know, X++ does not have the concept of characters in the defined in the language: Only strings are defined. However, it is not impossible to work with characters in X++, if you use the managed System.Char type. It will not win any prizes for elegance, but it works...
Consider the following example:
static void CharArray(Args _args)
System.Char[] chars;
System.Char a, b;
a = System.Char::Parse('a');
b = System.Char::Parse('b');
chars = new System.Char[2]();
chars.SetValue(a, 0);
chars.SetValue(b, 1);
Here an array containing to chars is created, and assigned the values {'a', 'b'}. Note the special trick used to create a character literal, using the System.Char::Parse method.
Удаленная работа с CRM и расширеный поиск ASheff Dynamics CRM: Разработка 64 04.06.2010 17:44
Доступ к данным из IFD CRM ZooY Dynamics CRM: Разработка 20 31.03.2010 11:18
Microsoft Dynamics CRM Team Blog: Working with System Views and Related Entities Blog bot Dynamics CRM: Blogs 0 02.03.2010 00:06
Не публикуется бизнес-процес Soulcar Dynamics CRM: Администрирование 6 04.02.2010 19:35
Часовой пояс GMT +3, время: 01:18.
