Старый 19.05.2011, 22:11   #1
25,643 / 848 (80) +++++++
Microsoft Dynamics CRM Team Blog: Announcing: Microsoft Dynamics CRM 2011 Implementation Guide update 5.1.0
Источник: http://blogs.msdn.com/b/crm/archive/...ate-5-1-0.aspx
Microsoft Dynamics CRM 2011 Implementation Guide update 5.1.0 is now available
Yes, it’s that time of year again where flowers are blooming, trees are burgeoning, and there’s a brand-spanking new update to the Microsoft Dynamics CRM 2011 Implementation Guide! Please note that this update will only be published to the TechNet and MSDN libraries.
Summary of changes
We strive to keep the information in this documentation as current and accurate as we can. The below table lists the changes that have been made as part of this documentation update. Guide
Topic
Type
Explanation
Planning
Business Manager's Role in a Microsoft Dynamics CRM Implementation
Revision
Moved the entire section out of the Planning Guide and moved it as a separate document that is not included with the Planning Tools download package.
Planning
Upgrading from Microsoft Dynamics CRM 4.0
Addition
Added a note that only the default organization is upgraded and additional organizations must be upgraded by using Deployment Manager.
Planning
SQL Server deployment considerations
Addition
Added bullet item about limited support when running Microsoft Dynamics CRM with a SQL Server that uses RCSI.
Planning
Active Directory and network requirements for Microsoft Dynamics CRM
Addition
Added a short sub-topic for IPv6 support.
Planning
Network ports for Microsoft Dynamics CRM
Addition
Added new subtopic for server role network port requirements.
Installing
Install Microsoft Dynamics CRM 2011 Server on a server without Microsoft Dynamics CRM installed
Revision
Revised Setup Wizard step on Specify E-mail Router Settings page to include that if you use a domain account for the Email Router service you must add that account to the PrivUserGroup.
Installing
Installing Microsoft Dynamics CRM for Outlook with Roaming User Profiles, Windows Server Remote Desktop Services, or Citrix Presentation Server
Addition
Added new topic for installing Microsoft Dynamics CRM for use with Citrix and Terminal Server.
Installing
Microsoft Dynamics CRM Reporting Extensions XML configuration file
Revision
Replaced "true/false" with "0/1" accepted values for autogroupmanagementoff element.
Installing
Sample Microsoft Dynamics CRM Reporting Extensions XML configuration file
Revision
Replaced "true/false" with "0/1" accepted values for autogroupmanagementoff and autoupdateconfigdb elements.
Cheers!
Matt Peart
Microsoft Dynamics CRM Team Blog: Released! Customer Care Accelerator for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 13.05.2011 23:12
Microsoft Dynamics CRM Team Blog: Update Rollup 1 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 3 09.04.2011 05:13
Microsoft Dynamics CRM Team Blog: Announcing the Customer and Partner Relationship Management Portals! Blog bot Dynamics CRM: Blogs 0 09.03.2011 02:21
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM 2011 ~ Book Club Blog bot Dynamics CRM: Blogs 0 02.02.2011 00:16
Microsoft Dynamics CRM Team Blog: Update Rollup 4 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 15.05.2009 09:06
Часовой пояс GMT +3, время: 10:32.
