Старый 15.06.2011, 03:25   #1
Preston.Larimer: Adding a custom lookup to a form control
Источник: http://palarimer.greenlight2go.com/2...m-control.html
In Dynamics AX one way you can add a custom lookup or drop down list to a form control by overriding the lookup method of the control. Below is some example code for doing this.
public void lookup()
     //This lookup basis the list criteria on information in 2 tables
     //All display fields come from Table1, Table2 is used for limiting criteria
     //super();
     //This Next Line initializes the the sysTableLookupClass
     sysTableLookup          sysTableLookup  =
                     SysTableLookup::newParameters(tableNum(<TABLENAME1>), this);
     Query                   query           = New Query();
     QueryBuildDataSource    qbdsTbl1, qbdsTbl2;
     QueryBuildRange         qbr;
     //Add Tables to the data source
     qbdsTbl1      = query.addDataSource(tableNum(<TABLENAME1>));
     qbdsTbl2     = qbdsTbl1.addDataSource(tableNum(TABLENAME2));
     //Add Query Ranges to limit List records
     qbr = qbdsTbl1.addRange(fieldNum(<TABLENAME1>,<RANGEFIELDNAME1>));
     qbr.value(<CRITERIAVALUE>);
     qbr = qbdsTbl1.addRange(fieldNum(<TABLENAME1>, <RANGEFIELDNAME2>));
     qbr = qbdsTbl1.addRange(fieldNum(<TABLENAME1>, <RANGEFIELDNAME3>));
     //Since we have multiple tables in the query turn on relations
     qbdsTbl1.relations(true);
     //Add Ranges to the Table2
     qbr = qbdsTbl2.addRange(fieldNum(<TABLENAME2>, <RANGEFIELDNAME4>));
     qbdsTbl2.relations(true);
     //The next 2 lines actualy adds the fields that will be displayed in the lookup grid
     sysTableLookup.addLookupfield(fieldNum(<TABLENAME1>, <DISPLAYFIELDNAME>));
     //Hand the created query to the sysTableLookupClass
     sysTableLookup.parmQuery(query);
     //Display the drop down
     sysTableLookup.performFormLookup();
Another example single table with field and table names instead of variable place holders
//Single table example with actual table and field names instead of  place holders
     //super();
                 SysTableLookup::newParameters(tableNum(salesBillOfLadingJournalTable), this);
     QueryBuildDataSource    qbdsJT, qbdsBLR;
     qbdsJT      = query.addDataSource(tableNum(salesBillOfLadingJournalTable));
     qbdsBLR     = qbdsJT.addDataSource(tableNum(salesBLReservation));
     qbr = qbdsJT.addRange(fieldNum(salesBillOfLadingJournalTable,isMaster));
     qbr.value(enum2str(noYes::No));
     qbr = qbdsJT.addRange(fieldNum(salesBillOfLadingJournalTable, custAccount));
     qbr.value((salesBillOfLadingJournalTableMaster.CustAccount));
     qbr = qbdsJT.addRange(fieldNum(salesBillOfLadingJournalTable, masterBLID));
     qbr.value(&quot;&quot;&quot;&quot;);
     qbdsJT.relations(true);
     qbr = qbdsBLR.addRange(fieldNum(salesBLReservation, blOpen));
     qbr.value(enum2str(noYes::Yes));
     qbdsBLR.relations(true);
     sysTableLookup.addLookupfield(fieldNum(salesBillOfLadingJournalTable, BillOfLadingID));
     sysTableLookup.addLookupfield(fieldNum(salesBillOfLadingJournalTable, salesID));
Последний раз редактировалось Poleax; 15.06.2011 в 09:42. Причина: оформление
Microsoft Dynamics CRM Team Blog: How to control surfacing of Custom Activity Blog bot Dynamics CRM: Blogs 0 17.05.2011 01:14
axhelper: To add lookup in form control Blog bot DAX Blogs 0 08.10.2010 14:05
Kashperuk Ivan: Lookup form returning more than one value Blog bot DAX Blogs 0 29.01.2010 18:05
gatesasbait: How to define a custom lookup form for an extended datatype Blog bot DAX Blogs 0 09.07.2008 22:05
Часовой пояс GMT +3, время: 14:34.
