|  08.07.2011, 18:11 | #1 |
| Участник |  axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010
			Источник: http://axforum.info/forums/blog.php?b=264 ============== Ну чтож, захотелось подружить Dynamics Ax 2009 c SharePoint Foundation 2010 и началось... :) Установленный SharePoint Foundation 2010 аксапта не видит, и жаждет SharePoint Services 3.0 Sp1 Далее читаем внимательно (информация в них дублируется, ставить КВ 2278963):
			Microsoft SharePoint 2010 is supported with Microsoft Dynamics AX 2009 Service Pack 1. If you plan to use SharePoint 2010, you must download and install the hotfix package available with Microsoft Knowledge Base article number 2278963. For more information about installing and deploying Enterprise Portal on SharePoint 2010, see the related post on the Microsoft Dynamics AX Sustained Engineering blog.
									3.	Clean Installation The following set of instructions iterates the installation steps for a clean installation of Enterprise Portal – Microsoft SharePoint 2010 on Microsoft Dynamics AX 2009 SP1. Assumptions: • Windows Server 2008 with Microsoft Dynamics AX 2009 SP1 without Enterprise Portal Role Center deployed. • Install Microsoft SharePoint 2010 • Create a new site in Microsoft SharePoint 2010 to ensure that Microsoft SharePoint 2010 is installed successfully. Выкрутасы с чистой установкой KB 2278963, все описано в Deployment of Microsoft SharePoint 2010 with Microsoft Dynamics AX 2009 SP1.docx • Step 1: Update setup To update the Setup application, follow these steps: 1. Copy the contents of the CD folder from the Microsoft Dynamics AX 2009 DVD to a shared network folder.• Step 2: Install Binary Patch 1. On any machine that has the Microsoft Dynamics AX 2009 client and AOS installed, run the AxUpdate.exe file from the Kernel directory of the hotfix package, and then follow the instructions that are provided by the Installation wizard.• Step 3: Install Application Patch 1. On any machine that has the Microsoft Dynamics AX 2009 client installed, run the AxUpdate.exe file from the Application directory of the hotfix package, and then follow the instructions that are provided by the Installation wizard.• Step 4 : Deploy Enterprise Portal Role Center by running Setup.exe from the CD folder Учтите, что KB974255 "Это обновление применимо к версии Microsoft Dynamics AX 5.0.1000.52-5.0.1500.2093 файлов приложения." ;) Время я только потратил, у меня Rollup 7. О ужас, KB 2278963 работает с "Это обновление применимо к версии 5.0.1000.52-5.0.1500.3560 файлов приложения." Т.е. 5.0.1500.3761 = 2009 SP1 Hotfix Rollup 6 (RU6), Rollup 7 = 5.0.1500.4570 Встрял на: Цитата:
									 === Запуск стадии выполнения ===  Запуск исполняемого файла клиента Microsoft Dynamics AX: C:\Program Files\Microsoft Dynamics AX\50\Client\bin\ax32.exe "-regconfig=Dev" "-logdir=C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2011-07-08 16-56-12" "-startupcmd=autorun_C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2011-07-08 16-56-12\GetVersionInformation.xml" Это обновление неприменимо к данной установке Microsoft Dynamics AX, поскольку установлены файлы приложения другой версии. Это обновление применимо к версии 5.0.1000.52-5.0.1500.3560 файлов приложения. Программе установки не удалось завершить установку. Это обновление неприменимо к данной установке Microsoft Dynamics AX. Продолжение следует .... ------------------------------------------------------------------------------------------------------------------------------------------------------------------ Связанная информация по KB2278963 из Knowledgebase:
 P.S. +
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 11.07.2011 в 11:17. Причина: оформление |
|  12.07.2011, 14:00 | #2 |
| Модератор |
			Как все поставить и нюансы установки в Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 - Этап 2
				__________________ This posting is provided "AS IS" with no warranties, and confers no rights. |
| За это сообщение автора поблагодарили: oip (5). | |
|  12.10.2017, 13:30 | #3 |
| Участник |
			Пытаюсь в очередной раз победить портал! Делаю все как указано тут и в блоге. Уже почти все, но на последнем этапе вылетает ошибка! Цитата:
			Вход в функцию ConfigureApplicationPool Ошибка во время установки Ролевые центры и корпоративный портал. Причина: Доступ к ликвидированному объекту невозможен.
				__________________ Axapta 3.0 sp - хз какой, kr2 |
|  13.10.2017, 11:14 | #4 |
| Участник |
			Есть Лог? У меня ощущение что я уже это побеждал в своё время )))
|  16.10.2017, 17:50 | #5 |
| Участник |
			Лог не сохранил. Собственно там написано то, что я выше привел.  Решил тем, что в мастере установки убрал галку "Создать сайт", а его уже потом создал вручную, из шаблона Axapta. Почти все заработало, кроме виджетов с отчетами! Пишет ошибку - Цитата:
			Ошибка при отображении отчета из папки  InventSpaceUtilization.InventSpaceUtilizationSiteWebpart.Report. Причина в  следующей ошибке: Невозможно чтение данных служб SQL Server Reporting Services.  Проверьте правильность URL-адреса диспетчера отчетов.
| Теги |
| ax2009, enterprise portal, role center, sharepoint |
