Старый 18.07.2011, 15:25   #1
ideveloper is offline
ideveloper
AIF Same SourceEndpoint in different Companies
Hi all.
Is it a good practice when I use the same name for the Source Endpoint (with different Destination Endpoints of course) or should a company have a Source Endpoint with own "name"?
I have tested the both solution. The difference (as I can see) is only the logging of the Messages:
Same name for Source Endpoint -> Messages are shown in the both companies
Different Source Endpoint names -> Messages are shown according to the companies
What is here the best practice?
Regards
ideveloper
Старый 18.07.2011, 16:52   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1850 (69) ++++++++
Сообщение от ideveloper Посмотреть сообщение
Ideally the system should not let you do so as now the external party cannot identify the sender
Should a company have a Source Endpoint with own "name"?
yes
-ТСЯ или -ТЬСЯ ?
Старый 19.07.2011, 10:20   #3
ideveloper
Thank you for your answer.
=> There are restrictions only on the Destination Endpoint; the name of the Source Endpoint is free choosable
aif, source endpoint
axinthefield: The AIF processing services used by each of the AIF adapters in AX 2009 Blog bot DAX Blogs 0 27.05.2011 05:12
Aku: Assistent für AIF-Dokumentendienste und Tabellen mit InventDimId Blog bot DAX Blogs 0 22.04.2011 17:11
daxdilip: How to: Configure Dynamics AX AIF Services to listen for SSL Requests (https) Blog bot DAX Blogs 0 23.01.2011 10:12
Channel9: Microsoft Dynamics AX 2009 AIF Web Services Screencast Blog bot DAX Blogs 0 17.06.2009 17:05
Dianne Siebold: AIF Top Ten Blog bot DAX Blogs 1 22.04.2008 11:19
Часовой пояс GMT +3, время: 12:51.
