Старый 18.08.2011, 18:11   #1
emeadaxsupport: Store Connect: error “Multiple-step operation generated errors”
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ed-errors.aspx
Area: Retail\Store
Connect
Affected product:
Dynamics AX 2009 SP1 RU6 RETAIL R2
Dynamics AX 2009 SP1 RU7 RETAIL R2 Refresh
Problem:
When deploying the data from AX HQ to the POS database, you
might encounter a problem with inserting the data to the POS database. In the
Retail Store connect database in the outgoing message the following error
message occurs.
Example
Multiple-step operation generated errors. Check each status
value., table 'ADDRESS': 5637213327
Reason:
When inserting the data to the POS tables it is not allowed
to insert data that exceed the maximum string size of the column. There are
around 150 columns on the POS that are less in size than in the HQ
database.
An example is CITY in the Address table. In the HQ database it is 60 characters and in POS database 30
characters. Adding a CITY with more than 30 character and then transfer the
N-1010 job that includes the ADDRESS table, the Store connect will fail.
Solution:
The solution is not out of the box, but here are two options.
1. In the Retail POS Plug-ins for partners, there is a
service which can be modified to include the correct databasescript. The
service is called CreateDatabase. The script can be replaced with one from this
blog post. You need to use Visual Studio to compile a new dll file.
2. Second option is to create the AxRetailPos database with a changed script.
The script provided in aligned to the R2 Refresh version.
If you want to gather information about the schema difference between the HQ DB and the POS DB
  • First, export the SQLDICTIONARY table from the HQ to the AXRETAILPOS
  • Run this job and see the difference in the string sizes
SELECT o.name as TABLENAME, c.name as "COLUMN NAME",
d2.strsize as HQ, c.max_length/2 as POS
FROM sys.objects o, sys.columns c, SQLDICTIONARY d1, SQLDICTIONARY d2
WHERE o.type_desc =
'USER_TABLE'
AND
o.object_id = c.object_id
AND
d1.fieldid = 0
AND
d1.SQLNAME = o.name
AND
d2.fieldid > 0
AND
d1.tableid = d2.tableid
AND
d2.SQLNAME = c.name
AND
c.system_type_id=231
AND
d2.strsize > (c.max_length/2)
ORDER BY o.name, c.name
3. Fields on HQ DB that are smaller
Tables with columns that are larger on POS than in
the HQ database.
No script provided, since changes made to the AX application, could break code or relations.
The same procedure as described above.
SELECT o.name as TABLENAME, c.name as "COLUMN NAME", d2.strsize
WHERE o.type_desc =
'USER_TABLE'
AND
AND
d1.fieldid = 0
AND d1.SQLNAME
= o.name
AND
d2.fieldid > 0
AND
AND
d2.SQLNAME = c.name
AND
AND
d2.strsize (c.max_length/2)
Output:
TABLENAME
COLUMN NAME
HQ
POS
POSFUNCTIONALITYPROFILE
CENTRALTABLESERVERPORT
10
50
POSHARDWAREPROFILE
DRAWERDEVICENAME
30
60
POSHARDWAREPROFILE
DUALDISPLAYIMAGEPATH
259
260
POSHARDWAREPROFILE
MSRDEVICENAME
30
60
POSISERRORS
CODEUNIT
100
250
POSISFORMLAYOUT
TITLE
30
50
POSISKEYBOARDBUTTONCONTROL
DEFAULTCOLOR
10
20
POSISKEYBOARDMAPPINGTRANS
KEYCHAR
1
10
POSISLANGUAGETEXT
LANGUAGEID
5
7
POSISLOG
LOGSTRING
0
1000
POSISTILLLAYOUT
RECEIPTID
10
18
RBOLOYALTYCUSTTABLE
STREET
60
250
RBOSTAFFTABLE
FIRSTNAME
20
30
RBOSTAFFTABLE
LASTNAME
20
30
RBOSTORETABLE
CULTURENAME
7
10
RBOTRANSACTIONSALESTRANS
CREATEDBY
5
10
DISCGROUPID
10
50
FILELOGID
10
20
RBOTRANSACTIONTABLE
CREATEDBY
5
10
Author: Kim
Editor: Kim
Date: 18. August 2011
emeadaxsupport: Store connect - IDispatch error #3119: Violation of PRIMARY KEY Blog bot DAX Blogs 0 18.08.2011 18:11
emeadaxsupport: How to: Add a new operation to AIF Document Service. Blog bot DAX Blogs 0 01.04.2011 00:12
emeadaxsupport: When using AX 2009 AIF Web Services errors may not always get propagated Blog bot DAX Blogs 0 09.11.2010 19:04
emeadaxsupport: Batch tasks show no operation progress Blog bot DAX Blogs 0 22.09.2010 23:05
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Часовой пояс GMT +3, время: 02:43.
