#1 |
palleagermark: Odd CIL compilation issue
Источник: http://palleagermark.blogspot.com/20...ion-issue.html
============== I'd really like some input on this article, if anyone has experienced something similar. I had a couple of CIL compilation errors today in an imported model. The errors all pertained to a new field that was added to a couple of tables. After setting a random LegacyId for the field, I was able to do a successful CIL compilation, and I was also able to compile successfully after removing the LegacyId again. I don't know if it was the LegacyId change that did the trick, or just the fact that I made a change to the tables. Please let me know if you have had similar issues and what ideas you may have to fix them. (And of course we did, without luck, try all the usual stuff, restarting AOS'es, recompiling X++ etc) Источник: http://palleagermark.blogspot.com/20...ion-issue.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
