Старый 18.02.2012, 01:13   #1
emeadaxsupport: Calling the Query Service
Источник: http://blogs.msdn.com/b/axsupport/ar...y-service.aspx
In AX 2012 some system services were added to perform generic functions like retrieving security or AOT node information. To me the most interesting system service is the Query service. This service allows you to perform a query against whatever tables you want from a service call. On the call you can specify a field list, range, sort, etc. The classes replicate the Query classes used on forms and queries inside of AX. Most notably, the query service has paging built into it. If you have a data intensive query you need to perform via a service call this is probably the right option for you. Service calls tend to timeout on the client when you retrieve a lot of data and don't have the ability to do paging. With that plug for the query service here are some examples I wrote that demonstrates how to use it:
This one has ranges and a sort and builds the whole query programmatically:
QueryServiceClient client = new QueryServiceClient();
DataSet dataSet;
//Set up paging so that 1000 records are retrieved at a time
Paging paging = new ValueBasedPaging() { RecordLimit = 1000 };
QueryMetadata query;
QueryDataSourceMetadata customerDataSource;
QueryDataRangeMetadata range, range2;
QueryDataOrderByMetadata sort;
QueryDataFieldMetadata accountNum, bankAccount, commissionGroup, cashDisc, custGroup;
query = new QueryMetadata();
// Set the properties of the query.
query.QueryType = QueryType.Join;
query.DataSources = new QueryDataSourceMetadata[1];
// Set the properties of the Customers data source.
customerDataSource = new QueryDataSourceMetadata();
customerDataSource.Name = "Customers";
customerDataSource.Enabled = true;
customerDataSource.Table = "CustTable";
//Add the data source to the query.
query.DataSources[0] = customerDataSource;
// Setting DynamicFieldList property to false so I can specify only a few fields
customerDataSource.DynamicFieldList = false;
customerDataSource.Fields = new QueryDataFieldMetadata[5];
//Add my fields
accountNum = new QueryDataFieldMetadata();
accountNum.FieldName = "AccountNum";
accountNum.SelectionField = SelectionField.Database;
customerDataSource.Fields[0] = accountNum;
bankAccount = new QueryDataFieldMetadata();
bankAccount.FieldName = "BankAccount";
bankAccount.SelectionField = SelectionField.Database;
customerDataSource.Fields[1] = bankAccount;
commissionGroup = new QueryDataFieldMetadata();
commissionGroup.FieldName = "CommissionGroup";
commissionGroup.SelectionField = SelectionField.Database;
customerDataSource.Fields[2] = commissionGroup;
cashDisc = new QueryDataFieldMetadata();
cashDisc.FieldName = "CashDisc";
cashDisc.SelectionField = SelectionField.Database;
customerDataSource.Fields[3] = cashDisc;
custGroup = new QueryDataFieldMetadata();
custGroup.FieldName = "CustGroup";
custGroup.SelectionField = SelectionField.Database;
customerDataSource.Fields[4] = custGroup;
//Put a range restriction on the query, in this case they will act as an or
//so the CustGroup == 20 || CustGroup == 30
range = new QueryDataRangeMetadata();
range.TableName = "CustTable";
range.FieldName = "CustGroup";
range.Value = "20";
range.Enabled = true;
range2 = new QueryDataRangeMetadata();
range2.TableName = "CustTable";
range2.FieldName = "CustGroup";
range2.Value = "30";
range2.Enabled = true;
customerDataSource.Ranges = new QueryDataRangeMetadata[2];
customerDataSource.Ranges[0] = range;
customerDataSource.Ranges[1] = range2;
//Add a sort
sort = new QueryDataOrderByMetadata();
sort.DataSource = "Customers";
sort.FieldName = "AccountNum";
sort.SortOrder = SortOrder.Ascending;
query.OrderByFields = new QueryOrderByMetadata[1];
query.OrderByFields[0] = sort;
// Execute the query
int i = 0;
do
dataSet = client.ExecuteQuery(query, ref paging);
Console.WriteLine("Query service call: " + i.ToString());
Console.WriteLine("Number of Records in CustTable: " + dataSet.Tables[0].Rows.Count.ToString());
DataRow firstReturnedRow = dataSet.Tables[0].Rows[0];
i++;
while (((ValueBasedPaging)paging).Bookmark != null);
Console.ReadLine();
This one executes a query modelled in the AOT:
Paging paging = new ValueBasedPaging() { RecordLimit = 10 };
DataSet dataset;
int i = 0;
do
dataset = client.ExecuteStaticQuery("CustTable", ref paging);
DataRow row = dataset.Tables[0].Rows[0];
i++;
For more information on the query service and the other system services check out msdn:
http://msdn.microsoft.com/en-us/library/gg879657.aspx
emeadaxsupport: AX for Retail: Tip for Troubleshooting the Retail Transaction Service Blog bot DAX Blogs 0 25.01.2012 10:11
AIF: OData Query Service Blog bot DAX Blogs 0 24.08.2011 09:11
DynamicsAxSCM: Service products in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 2 02.06.2011 13:36
emeadaxsupport: How to: Add a new operation to AIF Document Service. Blog bot DAX Blogs 0 01.04.2011 00:12
emeadaxsupport: Passing UtcDateTime values in extended query syntax Blog bot DAX Blogs 0 10.05.2010 21:05
Часовой пояс GMT +3, время: 05:35.
