#1 |
emeadaxsupport: Fixed Dimension Support in AX2012
Источник: http://blogs.msdn.com/b/axsupport/ar...in-ax2012.aspx
============== AX 2012 has provided a new dimension framework that includes a shared chart of accounts and system-backed financial dimensions. The concept commonly known as ‘Fixed dimensions’ available in releases prior to AX 2012 is supported differently in the new framework. 1. If your scenario is to fix a dimension value to “Blank” for a specific account prior to AX 2012, the new account structure functionality will provide this support. Account structures are used to determine the valid combinations of main account and financial dimension values that should be posted to a general ledger account. You can create multiple account structures that can be used by a chart of accounts. For example, you may have 2 different account structures such as this: Balance Sheet Segments included: Main Account+ Department Profit and Loss Segments included: Main Account + Department + Cost Center This setup will ensure that CostCenter is not available when recording entries against any of the main accounts that are defined in the range for the Balance Sheet account structure. 2. If your scenario is to fix a dimension value to a specified value for a specific account prior to AX 2012, you can set up the main account as an allocation account and define the allocation terms destination to be to the specific dimension value. When recording an entry against this account, the posting to general ledger will include this dimension value. For example, I want a specific cash account to always be posted with Department “001” but the offsetting profit and loss account may be posting to other department values. By selecting the main account (General ledger > Setup > Chart of accounts > Chart of accounts), and then selecting to view the main account for a specific company, select the “Allocation” checkbox in the general tab. The Allocation terms button will be enabled and you can select to define the allocation terms. Assuming my cash account number is 110020, and my account structure for this account is Main Account + Department, my allocation term would look like this: Percent allocation: 100.00 Source financial dimension criteria: Department: Unspecific (this means that this rule is in play no matter what department value is entered on the document) Destination ledger account: To account: 110020 To financial dimensions: Department: 001 This setup would then always post to department 001 when posting to main account 110020 for the specified company. 3. If your scenario is to fix a dimension value to a specified value for a specific account prior to AX 2012 because the dimension value is representing a sub account, you have another option. You can set up the main account number to include the dimension value instead of using a dimension. For example, using the cash account above, the main account number could be 110020001. Источник: http://blogs.msdn.com/b/axsupport/ar...in-ax2012.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
