Старый 02.03.2012, 01:18   #1
How to make a temporary instance of a database table to be shown on the form
Источник: http://alexvoy.blogspot.com/2012/03/...stance-of.html
This short code shows how to work with a temporary table without creating it in AOT.
// how to use temporary table
// method Init of the form
public void init()
    WmpInventNutrition        nut; // regular table in AOT
    WmpInventNutrition        tmp; // instead of creating in AOT a temporary table
                                   // we can create a temporary instance of the preivous regular table
     super();
    // here we make it temporary;
    // it will disappear from memory when loses the scope
    // in other words, when we close the form
    tmp.setTmp();
    // simply selecting some of records from the regular table
    while select nut
        where nut.ItemId like '_wmp*'
        // and putting them in the temporary one
        tmp.data(nut);
        tmp.doInsert();
    // finally to show them on the form
    // we set the form data source to the temporary table
    wmpInventNutrition.setTmp();
    wmpInventNutrition.setTmpData(tmp);
Alternatively, if you know exactly how the field match, it will be faster to use insert_recordset:
    tmp.skipDataMethods();
    insert_recordSet tmp (itemid) select ItemId from nut where nut.ItemId like '_wmp*';
Последний раз редактировалось Poleax; 02.03.2012 в 10:47. Причина: оформление
Paint it black: How to color rows in Table form control Blog bot DAX Blogs 0 12.07.2011 02:11
dynamicsaxtraining: How to make data from temporary table available in form’s grid Blog bot DAX Blogs 0 04.12.2010 01:11
emeadaxsupport: Wrong data shown in the grid, if the table field is an Int 64 and the form control is an IntEdit instead of an int64edit. Blog bot DAX Blogs 3 22.07.2010 18:00
PatrickChua: Temporary table Blog bot DAX Blogs 0 04.05.2009 14:05
Часовой пояс GMT +3, время: 00:43.
