Старый 31.07.2012, 00:11   #1
axaptacorner: Upgrade Process
Источник: http://axaptacorner.blogspot.com/201...e-process.html
Upgrade Process
Following are the steps in order to upgrade AX 2009 to 2012
Preprocessing upgrade checklist
AOD code upgrade checklist
Model code upgrade checklist
Data upgrade checklist
Prerequisite Steps
1. Verify that you have the proper amount of space on your target system hard drive and in your database transaction log.
2. Ensure that Microsoft SQL Server is configured for the highest possible performance and throughput.
3. Clean up Data
4. Activate multisite functionality when you upgrade from Microsoft Dynamics AX 2009 to Microsoft Dynamics AX 2012. before installing XPOClick Administration > Reports > System > Multisite activation readiness to open the report.
5. Trade and Logistics licenses after you upgrade.
6. Before you upgrade, if you are using virtual companies you must make the following changes to their configuration: Make sure that the inventory dimensions table is not shared. Make sure that tables that contain inventory dimension fields are not shared.
7. You will import the preprocessing XPO into the USR layer on the Microsoft Dynamics AX source system.
8. Be sure to back up your application files (*.aod) and label files (*.ald) before you import the preprocessing XPO
9. It is advisable to make sure that the Application Object Directory (AOD) is synchronized with the Microsoft Dynamics AX database schema before you begin to import of the XPO.
10. Install ALD files which are in DatabaseUpgrade\ALD path to C:\Program Files\Microsoft Dynamics AX\50\Application\Appl\Standard\ (Stop services before copy ALD file)
11. Import XPOs which are in DatabaseUpgrade\ALD path(clear with id check box option at the time of import)
12. Install CHM files Locate the file UpgradePreprocessing.chm in the DatabaseUpgrade\CHM folder on your installation media.
13. copy the file to C:\Program Files\Microsoft Dynamics AX\50\Client\Bin\Help\EN-US\.
14. Note: If you have customized any of the hybrid classes (\Classes\Session, \Classes\Application, \Classes\Company, \Classes\Info, \Classes\ClassFactory, or \Classes\VersionControl), remove the customizations before upgrading to Microsoft Dynamics AX 2012. And export it for target system.
Start Preprocessing check list
You install the framework for the Preprocessing upgrade checklist in the USR layer of the Microsoft Dynamics AX source system by importing an XPO file.
To start checklist Expand Shared Project and locate Ax50PreUpgradeFramework, Right-click it, and click Open.
Process flow to Execute check list on source System
1. Prepare for upgrade
Check upgrade readiness
 View and fix upgrade readiness issues
Initialize preprocessing)
2. Prepare application data for preprocessing
System parameters
 Set up number sequence for upgrade
 Company priority setup
 Update country/region codes
 Map country/region codes
 Default country/region
 Prepare financial dimension framework for upgrade
 Map fixed asset calendars
 Prepare currencies for upgrade
 Inventory dimension group upgrade
 Product upgrade (preprocessing)
 Configure site structure
 Map task groups to capabilities
 Product Builder Route
 nodes upgrade
 Units
 Unit conversions
 Fixed units
 Unit texts
 About purchase order upgrade
 User relations upgrade - invalid company users
 User relations upgrade missing contact person
 User relations upgrade duplicate user IDs
Select which employee number to upgrade
3. Preprocess data on live system
 Run live preprocessing scripts
 Country/region upgrade
 Party upgrade
 Run delta preprocessing scripts
4. Preprocess data in single-user mode
Enter into single-user mode
 Run single-user mode preprocessing scripts
emeadaxsupport: Multisite activation within the upgrade process Blog bot DAX Blogs 0 25.05.2012 02:13
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
dax-lessons: Process Industries RU7- BUP Layer upgrade Dynamics AX 5.0 [Rollup7 -BUP layer] Blog bot DAX Blogs 0 22.07.2011 16:11
dax-lessons: Process Industries BUP Layer – Upgrade to Dynamics AX 5.0 SP1 RU6 Blog bot DAX Blogs 0 01.05.2011 17:13
Microsoft Dynamics CRM Team Blog: Server Upgrade Process for the Beginner Blog bot Dynamics CRM: Blogs 0 15.12.2009 03:23
Часовой пояс GMT +3, время: 19:47.
