Старый 05.09.2012, 19:30   #1
zenaars is offline
zenaars
Roll-up recurrence frequency
Hello!
Do you know if it's possible to set the "Roll-up recurrence frequency" to something less than 24 hours with CRM 2011 On-demand?
Best regards,
Zenaars
Старый 06.09.2012, 23:19   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Yes. You can do this using System Settings dialog. Unfortunately I do not have English CRM version installed to show you screenshot.
I believe path would be: Settings area - Administration subarea - System Settings. Then go to "Goal" tab. Minimum recurrence frequency is one hour.
Hope this will help.
Последний раз редактировалось Артем Enot Грунин; 06.09.2012 в 23:23.
Microsoft Dynamics CRM Team Blog: Writing a Multi-Currency Aware Roll-up Plug-in Blog bot Dynamics CRM: Blogs 0 25.06.2011 00:11
Microsoft Dynamics CRM Team Blog: Demystifying Recurring Appointment update recurrence logic: How history of past instances is saved in CRM Blog bot Dynamics CRM: Blogs 0 25.04.2011 19:11
Часовой пояс GMT +3, время: 04:21.
