Старый 18.09.2012, 18:11   #1
ax-erp: Pass Query from dialog to Form and Filter records
Источник: http://microsoft-dynamics-ax-erp.blo...-form-and.html
Created a Runbase class which has dialog selection using QueryStr.
I need to pass this Query range selection to a form and need to filter records based on this query Selection. Call the form by passing the Query selection from the class
<div style="background-color: white; border: 0px; color: #333333; font-family: Georgia, 'Bitstream Charter', serif; font-size: 16px; line-height: 24px; margin-bottom: 24px; padding: 0px; vertical-align: baseline;">Args _args;
FormRun _formRun;
EmplId _empId;
_args = new Args(); // creating a object for args class
_args.name(formstr(xtgCummeInquiry)); // Form Menuitem
_args.caller(this); // Form Caller(Current Form is mentioned as this)
_args.object(CummeQueryRun.query());
_formRun = ClassFactory.formRunClass(_args);
//new FormRun(_args);
// Creating object for FormRun
_formRun.init(); // Form Initialization for Load
_formRun.run(); // Form Run for process
_formRun.wait(); // Form Wait for Display
and from the called form run method,assign the Query range value to the form datasource
public void run()
boolean ret;
Query q;
DictField dictField;
str fieldLabel;
Addressing PrintRange;
int i, j, rangeCount;
QueryBuildRange QBR;
QueryRun Qrun;
super();
if(element.args().caller())
CallerOBJ = element.args().caller();
Qrun = CallerObj.QueryRun();
q = QRun.query();
for(i = 1; i
ax-erp: Reporting Framework in AX 2012 Blog bot DAX Blogs 0 19.07.2012 01:11
ax-erp: How to filter records in a form by code Blog bot DAX Blogs 0 13.06.2012 16:11
hariprasadp: Grid Filter while open a form in Dynamics AX Blog bot DAX Blogs 0 07.05.2008 15:05
Часовой пояс GMT +3, время: 03:12.
