Старый 06.11.2012, 08:11   #1
Malaysia: Adding a document handling note
Источник: http://axmas.blogspot.com/2012/11/ad...ling-note.html
static void VendAccountDocu(Args _args)
DocuRef docuRef;
VendTable vendTable;
vendTable = VendTable::find('3001');
docuRef.RefCompanyId = vendTable.dataAreaId;
docuRef.RefTableId = vendTable.TableId;
docuRef.RefRecId = vendTable.RecId;
docuRef.TypeId = 'Note';
docuRef.Name = 'Imported';
docuRef.Notes = 'This vendor was imported.';
docuRef.insert();
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 18.09.2010 22:05
Shekhar: Dynamics AX : Document handling Blog bot DAX Blogs 0 30.03.2010 15:05
paruvella: Dynamics Ax Document Handling For The Mails Using Drag n Drop Blog bot DAX Blogs 0 20.11.2009 20:05
paruvella: Dynamics Ax Document Handling using File Drag n Drop Blog bot DAX Blogs 0 12.11.2009 21:05
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 23:32.
