Старый 20.11.2012, 19:30   #1
pawan is offline
pawan
? Throwing Error: Argument '_number' is incompatible with the required type.
I have written the code for updating Purchase Order Invoice in my customized Form in write method to update from that customized Form
     PurchFormLetter_Invoice     invoice;
    super();
    purchTable = PurchTable::find(nNS_CITPickUpReconcil.PONumber);
    invoice = PurchFormletter::construct(DocumentStatus::Invoice);
    invoice.update(purchtable,
    SystemDateGet(),
    PurchUpdate::All,
    AccountOrder::None,
    false,
    true);
But its throwing error as below:
Старый 20.11.2012, 19:39   #2
S.Kuskov is offline
S.Kuskov
3,449 / 1792 (66) ++++++++
http://msdn.microsoft.com/en-us/libr...(v=ax.50).aspx
Check your second parameters.
P.S.: It's no good idea to place this code in forms method...
Последний раз редактировалось S.Kuskov; 20.11.2012 в 19:44.
Старый 20.11.2012, 19:52   #3
pawan is offline
pawan
So can you please what should i have to do???
Старый 20.11.2012, 20:22   #4
S.Kuskov is offline
S.Kuskov
Сообщение от pawan Посмотреть сообщение
You must send in PurchFormLetter_Invoice.update() Invoice Number value as second parameter
Старый 21.11.2012, 02:12   #6
lvan is offline
lvan
Аватар для lvan
858 / 82 (4) ++++
угадайте горе-клиента и партнера?
Старый 21.11.2012, 02:56   #7
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Сообщение от lvan Посмотреть сообщение
расскажите неместным, интересно
Часовой пояс GMT +3, время: 17:13.
