Старый 12.12.2012, 00:11   #1
dynamicscare: Error Fixed: Table ‘ShipCarrierTracking’ of type TempDB cannot be changed to table of type InMemory.
Источник: http://dynamicscare.com/blog/index.p...type-inmemory/
With Dynamics AX 2012 CU3, we have been experiencing this error when opening the Packing Slip Journals form from a Sales Order: “Table ‘ShipCarrierTracking’ of type TempDB cannot be changed to table of type InMemory.” After many headaches, I believe we have finally figured out the culprit. Keep reading to find out. I’ve seen several blogs [...]
kamalblogs: Dynamics ax 2012 – Copying Temp Table instance for SQL TempDB Blog bot DAX Blogs 0 12.07.2012 00:14
dynamicscare: Exception of type ‘Microsoft.Dynamics.Ax.Xpp.ErrorException’ Blog bot DAX Blogs 0 10.11.2011 19:11
dynamics-ax: Dynamics AX 2012 - Table & Type Hierarchies Blog bot DAX Blogs 0 27.01.2011 00:13
palleagermark: Dealing with changed table or field id's Blog bot DAX Blogs 0 11.02.2009 11:05
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
Часовой пояс GMT +3, время: 13:01.
