Старый 18.01.2013, 20:11   #1
axaptacorner: Upgrade from Ax 2012 to AX 2012 R2
Источник: http://axaptacorner.blogspot.com/201...x-2012-r2.html
In-Place upgrade Ax 2012 R2
The recommended approach for the in-place upgrade(upgrade from ax 2012 or ax 2012 feature pack to Ax 2012 R2) requires three system as:
1.Production: Existing system which you want to upgrade
2.Test: Copy of the production system to upgrade data base architecture
3.Development: to upgrade the code and metadata
Process flow through the above architecture are as--
Step 1:
In the earlier version we have the business data and model stores in the same data base
So in the first step on the test system data will split in the two different data base one is business data and other is model stores.
Note: But in this process all the additional component like EP, Reporting services, Analysis service and retail component does not exist on the test system, Mince add only Database, AOS, Debugger and Client while run AX 2012 R2 setup.
After running the R2 setup export the Upgraded models
Steps 2:
Make duplicate copy of test on the development system and upgrade customer models
Steps 3:
Import the upgraded model on the test system and complete the data upgrade in the test system
Step 4:
Run the setup on the production system and complete the checklist
At the time running check list use the upgraded data and the models
Steps 5:
Upgrade the additional components like EP, Reporting Services etc
Steps 6:
Upgrade the Clients
Happy DAXing !!!!
axaptacorner: Ax 2012 CU3 Upgrade from AX 2012 Blog bot DAX Blogs 0 18.01.2013 20:11
amer-ax: It was a great day! Blog bot DAX Blogs 3 29.12.2012 01:02
Часовой пояс GMT +3, время: 16:04.
