#1 |
mbsturk: AppFabric, PSModulePath and Error Code 1603
Источник: http://mbsturk.blogspot.com/2013/01/...rror-code.html
============== "AppFabric installation failed because installer MSI returned with error code : 1603"with the following information in the log file. 2012-10-12 17:15:42, Information Setup Process.ExitCode: 0x00000643 2012-10-12 17:15:42, Error Setup AppFabric installation failed because installer MSI returned with error code : 1603 may not be the most fun way to spend a Monday evening. However, help is on the way. I was able to resolve it by fixing the path for environment variable psmodulepath to this C:\Windows\System32\WindowsPowerShell\v1.0\;c:\Program Files\AppFabric 1.1 for Windows Server\PowershellModules;C:\Program Files\Service Bus\1.0\ and it worked. The installation for both hosting and caching modulde was completed successfully. Detailed failure log below. 2012-10-12 16:44:42, Information Setup ===== Logging started: 2012-10-12 16:44:42-07:00 ===== 2012-10-12 16:44:42, Information Setup File: c:\66b691ef98af045bad18f4250b4b18\setup.exe 2012-10-12 16:44:42, Information Setup InternalName: Setup.exe 2012-10-12 16:44:42, Information Setup OriginalFilename: Setup.exe 2012-10-12 16:44:42, Information Setup FileVersion: 1.1.2106.32 2012-10-12 16:44:42, Information Setup FileDescription: Setup.exe 2012-10-12 16:44:42, Information Setup Product: Microsoft(R) Windows(R) Server AppFabric 2012-10-12 16:44:42, Information Setup ProductVersion: 1.1.2106.32 2012-10-12 16:44:42, Information Setup Debug: False 2012-10-12 16:44:42, Information Setup Patched: False 2012-10-12 16:44:42, Information Setup PreRelease: False 2012-10-12 16:44:42, Information Setup PrivateBuild: False 2012-10-12 16:44:42, Information Setup SpecialBuild: False 2012-10-12 16:44:42, Information Setup Language: Language Neutral 2012-10-12 16:44:42, Information Setup 2012-10-12 16:44:42, Information Setup OS Name: Windows 7 Professional 2012-10-12 16:44:42, Information Setup OS Edition: Professional 2012-10-12 16:44:42, Information Setup OSVersion: Microsoft Windows NT 6.1.7601 Service Pack 1 2012-10-12 16:44:42, Information Setup CurrentCulture: en-US 2012-10-12 16:44:42, Information Setup Processor Architecture: AMD64 2012-10-12 16:44:42, Information Setup Event Registration Source : AppFabric_Setup 2012-10-12 16:44:42, Information Setup 2012-10-12 16:44:42, Information Setup Microsoft.ApplicationServer.Setup.Upgrade.V1UpgradeSetupModule : Initiating V1.0 Upgrade module. 2012-10-12 17:15:21, Information Setup Microsoft.ApplicationServer.Setup.Upgrade.V1UpgradeSetupModule : Initiating V1 Upgrade pre-install. 2012-10-12 17:15:21, Information Setup Microsoft.ApplicationServer.Setup.Upgrade.V1UpgradeSetupModule : V1.0 is not installed, not taking backup. 2012-10-12 17:15:21, Information Setup Enumerating Windows features 2012-10-12 17:15:33, Information Setup Windows features successfully enabled. 2012-10-12 17:15:33, Information Setup Process.Start: C:\Windows\system32\msiexec.exe /quiet /norestart /i "{96E70525-4CD1-4920-9C0B-91055C79A962}" ADDDEFAULT=WorkerAdmin,Setup /l*vx "C:\Users\adnan.masood\AppData\Local\Temp\AppServerSetup1_1(2012-10-12 17-15-33).log" LOGFILE="C:\Users\adnan.masood\AppData\Local\Temp\AppServerSetup1_1_CustomActions(2012-10-12 17-15-33).log" INSTALLDIR="c:\Program Files\AppFabric 1.1 for Windows Server\" LANGID=en-US 2012-10-12 17:15:42, Information Setup Process.ExitCode: 0x00000643 2012-10-12 17:15:42, Error Setup AppFabric installation failed because installer MSI returned with error code : 1603 2012-10-12 17:15:42, Error Setup 2012-10-12 17:15:42, Error Setup AppFabric installation failed because installer MSI returned with error code : 1603 2012-10-12 17:15:42, Error Setup 2012-10-12 17:15:42, Information Setup Microsoft.ApplicationServer.Setup.Core.SetupException: AppFabric installation failed because installer MSI returned with error code : 1603 2012-10-12 17:15:42, Information Setup at Microsoft.ApplicationServer.Setup.Installer.WindowsInstallerProxy.GenerateAndThrowSetupException(Int32 exitCode, LogEventSource logEventSource) 2012-10-12 17:15:42, Information Setup at Microsoft.ApplicationServer.Setup.Installer.WindowsInstallerProxy.Invoke(LogEventSource logEventSource, InstallMode installMode, String packageIdentity, List`1 updateList, List`1 customArguments) 2012-10-12 17:15:42, Information Setup at Microsoft.ApplicationServer.Setup.Installer.MsiInstaller.InstallSelectedFeatures() 2012-10-12 17:15:42, Information Setup at Microsoft.ApplicationServer.Setup.Installer.MsiInstaller.Install() 2012-10-12 17:15:42, Information Setup at Microsoft.ApplicationServer.Setup.Client.ProgressPage.StartAction() 2012-10-12 17:15:42, Information Setup 2012-10-12 17:15:42, Information Setup === Summary of Actions === 2012-10-12 17:15:42, Information Setup Required Windows components : Completed Successfully 2012-10-12 17:15:42, Information Setup Microsoft .NET Framework 3.5.1 : Completed Successfully 2012-10-12 17:15:42, Information Setup IIS Management Console : Completed Successfully 2012-10-12 17:15:42, Information Setup AppFabric 1.1 for Windows Server : Failed 2012-10-12 17:15:42, Information Setup Hosting Administration : Failed 2012-10-12 17:15:42, Information Setup Microsoft Update : Skipped 2012-10-12 17:15:42, Information Setup Microsoft Update : Skipped 2012-10-12 17:15:42, Information Setup 2012-10-12 17:15:42, Information Setup ===== Logging stopped: 2012-10-12 17:15:42-07:00 ===== Источник: http://mbsturk.blogspot.com/2013/01/...rror-code.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
