Старый 26.01.2013, 02:14   #1
emeadaxsupport: Corrupted data that may prevent you to post a purchase invoice
Источник: http://blogs.msdn.com/b/axsupport/ar...e-invoice.aspx
You may have a situation like the following ones:
  • There is pending invoice in AX that is not visible in invoicepool. It can be seen only from purchase order side. It blocks many orders.
  • A Pending Invoice is not appearing in PL>common>Pending Supplier Invoices however when you go to the PO and look at the invoice tab, the Pending Invoice is still highlighted and when you select this you can see the detail of the pending invoice but we cannot do anything with it
  • When trying to post a purchase invoice you get an error message that says: Invoice %1 could not post because it contained matching errors which must be approved.
  • While selecting Pending vendor invoice gets an error as “One or more pending invoices cannot be displayed because they are in use” and the invoice is not displayed.
Scenarios where you cannot complete purchase invoicing.
It may happen that if AOS gets stopped suddenly or the client loses connection with the AOS, some records stay in specific tables that causes those issues.
Here is a list of the SQL tables where the 'pending' record may exist. If the record is found in any of the following tables, the recommendation is to remove it (please, do it in a test environment before that a live one and having NO users working in the application). Then, check to see if you are able to properly invoice update the PO.
PurchParmTable
PurchParmLine
PurchParmSubTable
PurchParmSubLine
PurchParmUpdate
VendInvoiceInfoTable
VendInvoiceInfoLine
VendInvoiceInfoSubTable
VendInvoiceInfoSubLine
If you want to delete these record going through Forms, here another option:
1. Firstly checking PurchParm tables when looking History forms (Account Payable/ Inquiries/ History/ Purchase orders), and delete in (ckeck in record status is "Waiting").
2. The next step is to check VendInvoiceInfo tables where you found the wrong records, You can access those records in the list page: Accounts payable module > Places > Pending Purchase Order Invoices. Here you can delete it as well. Note: pending invoice of your case will be in this list page.
Hope it's helpful
Kind regards
Marialecia Guada
Dynamics AX SCM Technical Lead
Старый 27.01.2013, 18:11   #2
trud is offline
trud
1,039 / 1635 (57) ++++++++
Сообщение от Blog bot Посмотреть сообщение
Вот это конечно круто. Т.е. теперь в разработчики sys слоя берут даже тех, кто не умеет пользоваться транзакциями
и отвал соединения при разноске будет приводить к порче бд
Старый 28.01.2013, 00:47   #3
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Ну, с учетом отличного (от остальных) склада ума у разработчиков моногочисленных приобретенных "решений" - чему ж удивляться. Ну, проскочило каким-то образом в релиз - бывает, починят. Странно то, что публикуют в блоге вместо экстренного выпуска фикса. Надеюсь, починят к тому времени когда мы запускаться будем
-ТСЯ или -ТЬСЯ ?
Старый 28.01.2013, 11:32   #4
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
Я так понимаю, это не связано с "решениями". Это в 2009 появилось в стандарте как возможность вводить "предварительные" накладные и проводить сравнение заказ - отборочная - накладная. Но в итоге действительно выдает неожиданные результаты, даже если ничем из этого не пользоваться
Ivanhoe as is..
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
emeadaxsupport: Why Purchase order invoice did not post any transaction on the balance account for Accounts payable Blog bot DAX Blogs 0 06.09.2012 04:43
emeadaxsupport: Can't find the packing slip during invoice matching or is the invoice form not showing any order lines? Blog bot DAX Blogs 0 11.06.2012 22:13
Shekhar: Invoice journal linked with Purchase order Blog bot DAX Blogs 0 31.05.2010 22:05
Часовой пояс GMT +3, время: 12:13.
