Старый 28.01.2013, 20:13   #1
axaptacorner: Layer filter bug in AX 2009 RU-7
Источник: http://axaptacorner.blogspot.com/201...2009-ru-7.html
Layer filter bug in AX 2009 RU-7:
Hi Friend we are again here with a interesting and important fact. I was tring to filter a layer though the project in AX 2009 RU-7 but it did't created any object in the project. really it is a bug in the AX 2009 RU-7 and partner source there is a hot fix to fix this bug.
for more details navigate to following link--
http://www.msdynamicsax.info/2011/07/problem-in-building-project-using.html
http://palleagermark.blogspot.in/2011/06/unable-to-create-project-with-project.html
msdax: Dynamics AX 2009 Enterprise Portal Web Controls are stored in USR instead of BUS Layer Blog bot DAX Blogs 0 30.03.2011 18:11
Arijit Basu: AX 2009 Documents Blog bot DAX Blogs 0 30.08.2008 13:05
Часовой пояс GMT +3, время: 22:34.
