Старый 13.03.2013, 19:13   #1
emeadaxsupport: Deploying reports in AX2012 - you need access to the administrative share C$
Источник: http://blogs.msdn.com/b/axsupport/ar...e-share-c.aspx
ISSUE
When deploying reports in AX2012 you might run into the following error: "The network name cannot be found"
You can see the error occurred when deploying the assemblies.
Below is an example where we did not get the error and I am running the -Verbose command to see where we are running into the error.
We were getting the "The network name cannot be found" error when we are creating the assemblies in the temporary location at \\dax2012\C$\TEMP\AXSRSAssemblies.
The key here is that we are creating the assemblies in the hidden share C$.
SOLUTION
The cause of this error is that access to the Administrative share C$ has been disabled.
By default, Windows Server 2008 automatically creates special hidden administrative shares that administrators, programs, and services can use to manage the computer environment or network. These special shared resources are not visible in Windows Explorer or in My Computer. However, you can view them by using the Shared Folders tool in Computer Management.
Therefore when deploying reports please make sure you have access to the administrative share C$.
emeadaxsupport: AX 2012 reports fail to deploy on a server hosting multiple SQL Server Reporting Server instances Blog bot DAX Blogs 0 15.06.2012 11:11
emeadaxsupport: When deploying reports to a SQL Reporting Instance using a host header/clustered NLB hostname you get an error - The network path was not found Blog bot DAX Blogs 0 14.03.2012 08:11
emeadaxsupport: Error "Cannot access a disposed object" when deploying AX 2009 Enterprise Portal on a SharePoint 2010 server Blog bot DAX Blogs 0 01.10.2010 20:05
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: Error access SSRS reports - System.Web.Configuration.RegexWorker threw an exception Blog bot DAX Blogs 0 04.12.2009 02:05
Часовой пояс GMT +3, время: 05:21.
