#1 |
emeadaxsupport: Ax2012R2 Report does not display any records in Report Viewer
Источник: http://blogs.msdn.com/b/axsupport/ar...rt-viewer.aspx
============== Issue: No information is displayed in report viewer for a customer report Reason: In this situation an image was added to the report footer for the purpose of an electronic signature. When this image was removed from the report, the report did print correctly. After further investigation it was found the image was 'corrupted', a different image was utilized and the report printed correctly. Источник: http://blogs.msdn.com/b/axsupport/ar...rt-viewer.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
