Старый 01.04.2013, 14:11   #1
Baseline model store database
Источник: http://dev.goshoom.net/en/2013/03/ba...tore-database/
In AX2012 R2, model store database has been separated from business data database. For upgrade purposes, we have one more database – baseline model store. AOS configuration in Windows registry therefore contains keys for three database servers:
  • dbserver
  • ModelDBServer
  • ModelDBServer_baseline
(They’re stored at HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Dynamics Server\6.0\02\{config name}\.)
But if you open Microsoft Dynamics AX 2012 Server Configuration, you’ll see only one field for database server name:
If you change the value in Server name field, both database lookups correctly list databases from the new database server. But… only two registry keys are updated: dbserver and ModelDBServer. ModelDBServer_baseline is not changed, therefore AX will try to read baseline model store from the original server. If you had moved databases to another server (as we did), the DB doesn’t exist on the original server anymore.
AOS starts even with this configuration, but the baseline model store is not available – you can’t compare objects with old layers, layer conflict detection wouldn’t work, AOD files can’t be imported to baseline… Fortunately you can find some helpful messages in Event Viewer (on the machine with AOS):
Object Server 01: SQL diagnostics: [Microsoft][SQL Server Native Client 10.0][SQL Server]Login failed for user ‘OurDomain\AosServiceAccount’.. Connect information was: Userid = [], Database = [R2DevBaseLine], Server = [DbServerA], DSN = [], Other = []
Object Server 02: The database DbServerA\ is not recognized as a model store.
DBServerA is the original server, not the one currently configured to be used by AOS – that’s quite clear indication where things went wrong.
The only solution is to update the value of ModelDBServer_baseline directly in registry.
A similar problem may exist in AX2012 (without R2) too, but I didn’t test that.
ax2012, baseline, modelstore
axaptacorner: Model, Model Stores and Base Line Data base in ax 2012 Blog bot DAX Blogs 0 10.01.2013 13:11
sumitax: Ax2012 – Model store Blog bot DAX Blogs 0 30.06.2012 20:12
sjakalax: The model store has been modified Blog bot DAX Blogs 0 23.01.2012 16:11
axinthefield: Database Mirroring with Dynamics AX Blog bot DAX Blogs 1 20.01.2011 10:54
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
Часовой пояс GMT +3, время: 11:18.
