Старый 30.04.2013, 01:13   #1
dax-lessons: Get the underlying SSRS Report Query, reset query , add your own ranges and execute report [Dynamics AX 2012, X++]
Источник: http://dynamicsaxgyan.wordpress.com/...ics-ax-2012-x/
Friends, Below is the small code snippet to get the underlying query of the SSRS report, reset query, prompt the parameters form, add our own ranges and execute the report. You can customize the job as per your requirements. Below I have used CustBaseData.Report report and added my own range on customer group. static void [...]
crminthefield: Improving Dynamics CRM Report Performance – Part 1 “The Basics” Blog bot Dynamics CRM: Blogs 0 28.01.2013 20:13
axStart: Please keep the AOT reports in Dynamics AX next release alive Blog bot DAX Blogs 0 09.06.2010 08:05
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges Blog bot DAX Blogs 0 08.01.2010 16:05
Dynamics AX Geek: Using query() Blog bot DAX Blogs 0 04.05.2009 14:05
axStart: Please keep the AOT reports in Dynamics AX next release alive Blog bot DAX Blogs 2 13.12.2008 12:18
Часовой пояс GMT +3, время: 04:01.
