#1 |
Dynamics AX Sustained Engineering: Improve your chances for fast case turnaround
Источник: http://blogs.technet.com/b/dynamicsa...urnaround.aspx
============== I’m going to share a few tips and tricks with you on how to improve your chances for getting fast case turnaround times. These are especially important if you are reporting a bug. Behind the Scenes What I’m about to reveal is top secret, so don’t share it with anyone outside your immediate team! The diagram in Figure 1 describes the end-to-end workflow that happens when you file a problem report with Microsoft support. Figure 1 Problem Report End-to-end Workflow It doesn’t take a rocket scientist to figure out that if you have discovered a bug and you need a hotfix in the shortest possible time, you have to get your problem report to the Product Group as fast as possible. Here’s another secret. To ensure the most effective use of the Product Group’s time, they require the 2nd-level support team to submit problem reports in a special format. We call this format the “Good” Problem Report Template. We’ve provided an Excel template of the Problem Report Template. Entry Comment ACCURATE, DESCRIPTIVE TITLE? Does the problem report have an ACCURATE, DESCRIPTIVE TITLE? PROBLEM DESCRIPTION? Does the problem report have a business focused PROBLEM DESCRIPTION? BUSINESS PROCESS/SCENARIO Does the problem report describe the BUSINESS PROCESS/SCENARIO in an implementation free manner? IMPACT STATEMENT Does the problem report have an IMPACT STATEMENT that is short and to the point? REPRO STEPS, with ACTUAL RESULTS and EXPECTED RESULTS? Does the problem report have clear REPRO STEPS, with ACTUAL RESULTS and EXPECTED RESULTS? Figure 2 the 'Good' Problem Report Template Submitting a request Use this format when you submit a New Support Request, in the Please tell us about your problem section. In the Brief subject line field, enter an accurate, descriptive title. In the Detail of question or problem field, enter the following: Please see attached Problem Report Template. Submit your problem report template in the Additional file attachments section. Example 1 Consider the following two problem reports: which has the best chance for a quick turnaround--Problem Report A or Problem Report B? Problem Report A: When opening Kanban Schedule Board I get an error. The error is an - Unhandled exception: Unable to cast object of type 'System.DBNull' to type 'System.String' Problem Report B: ACCURATE, DESCRIPTIVE TITLE Error when opening Kanban Schedule Board - Unhandled exception: Unable to cast object of type 'System.DBNull' to type 'System.String' PROBLEM DESCRIPTION Error when opening Kanban Schedule Board - Unhandled exception: Unable to cast object of type 'System.DBNull' to type 'System.String' BUSINESS PROCESS/SCENARIO The customer does not use Product Dimensions and has disabled them in license configuration to prevent them from being used. IMPACT STATEMENT The customer is forced to enable product dimensions in order to use Kanbans. REPRO STEPS, with ACTUAL RESULTS and EXPECTED RESULTS 1. Unmark the following License Configuration options System administration > Licensing > License Configuration Product dimension – color Product dimension – Configuration Product dimension – Size Click Apply Click Ok Click Yes Click Continue 2. Exit Dynamics AX Client 3. Restart the AOS 4. Relaunch AX Client 5 Open Kanban schdule board window Production Control > Lean Manufacturing > Kanban schedule board Pick any Work cell if prompted Actual Result: Unhandled exception: Expected Result: No Error Example 2 Consider the following two problem reports: which has the best chance for a quick turnaround--Problem Report A or Problem Report B? Problem Report A: Can’t change the category selected in the expense category combo box if it is selected in the Itemization page. Is this a known problem? Problem Report B: ACCURATE, DESCRIPTIVE TITLE? Unable to change the category selected in the expense category combo box in EP once it is selected in the Itemization page PROBLEM DESCRIPTION? Once the expense category is selected in the Itemize fast tab in the itemization page it cannot be changed any longer. If you click on the dropdown again, no categories are shown in the lookup, only an OK and Cancel button. BUSINESS PROCESS/SCENARIO It is possible to change the category of the itemized line once the line has been added to the itemized lines grid. Therefore it should be also possible to change it before it gets added to the grid, because people might have made a mistake and want to correct it before they add the itemized line. IMPACT STATEMENT This causes confusion for users entering expense reports. This is a common scenario. REPRO STEPS, with ACTUAL RESULTS and EXPECTED RESULTS? Login to EP Click button "New Expense" Click button "Continue" Enter any string as the Expense Purpose Click button "Add new expense" and select Expense category as "Hotel" Enter the Transaction Date as "Today" Enter the Transaction amount as "70" Click button "Itemize" Select from the lookup Category = Room Service Click on the Category lookup for the second time Actual Result: Not able to select the category for the second time Expected Result: Should be able to select any category for the second time More Tips Submitting an additional repro document with screen shots, or a repro video can also greatly speed up our triage process, and the movement of a problem report through the end-to-end process. A repro video of the issue occurring can also assist the team to run through the scenario during the triage meeting quickly. Important: Even if you describe the repro steps in detail in a supplemental repro document, or attach a video, you should still summarize the steps in the repro section of the Problem Report Template. Attachments don’t replace repro steps—they just make them easier to understand. Источник: http://blogs.technet.com/b/dynamicsa...urnaround.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
#2 |
emeadaxsupport: Logging an incident for a possible code defect
Источник: http://blogs.msdn.com/b/axsupport/ar...de-defect.aspx
============== Hello all - Our In-Market Engineering team (formerly known as Sustained Engineering) has logged a blog post with some tips on what information to include when you open a support case that might turn into a code defect investigation. Check it out on their official blog at http://blogs.technet.com/b/dynamicsa...urnaround.aspx Kevin Источник: http://blogs.msdn.com/b/axsupport/ar...de-defect.aspx
