Старый 17.07.2013, 14:11   #1
axmfg: Product configurator, new Calculations concept
Источник: http://blogs.msdn.com/b/axmfg/archiv...s-concept.aspx
In cumulative update 6 for Dynamics AX 2012 R2 we are introducing a new concept
called Calculations in the Constraint-based product configuration models.
Calculations have many similarities with constraints in the way they are
created and maintained, but constraints are focused on limiting the number of
possible combinations and Calculations to enable mathematical expressions. One other
important difference between Constraints and Calculations is that Calculations
can work with decimal numbers. So for instance if the cable length for a home
theater system is decided by the room size it could be expressed as in the
screenshot example below.
If[ RoomSize / 1.33 > 7.5, 3.33, 6.66]
The image below shows how Calculations are defined for a product configuration model.
A Calculation, much like other product configuration model concepts, has a name
and a description to allow you to state the purpose of the Calculation.
Calculation expressions are uni-directional and the Target attribute receives the value
from the expression. The attributes can not be of type free text.
(It is possible to use a Text with a fixed list, also known as an Enumeration, but for a Target attribute of this type the return vale has to be the Integer order of the text value in the text list)
An attribute can both be used as a target attribute and
in expressions for other target attributes. The order of the calculations will
be determined accordingly.
The Calculation expression holds the logical or mathematical expression that
represents the Calculation. The expression syntax is similar to the syntax
available for expression constraints, but a wider range of operators are
available, such as the If operator shown in the example above. Also, both
decimal numbers and unbound integers can be used both as Target attributes and
in the Calculation expression. You can type the calculation expression yourself,
or build it using the new expression editor (Screenshot below). This is also a
new capability in CU6, and I will give a more detailed introduction in my next
post.
This enhancement makes it possible to manipulate decimal numbers at run-time during
configuration; you no longer need to express this type of operation through the
dedicated application programming interface represented by the PCAdaptor class.
In the screenshot above, the Target attribute is of type decimal number and it can be
used as a property on a bill of material (BOM) line or a route operation, but
it cannot be included in a constraint or a condition. If you want to control
the inclusion of a certain BOM line or route operation, this can be achieved by
using a Target attribute of type Boolean and then using the Target attribute in
the condition on the BOM line or route operation. Please see example below:
Target attribute: widthLengthRatioBoolean
Calculation: widthAttribute > lengthAttribute
BOM line condition: widthLengthRatioBoolean
Route operation condition: !widthLengthRatioBoolean
In this example the widthLengthRatioBoolean attribute takes the value true if the
widthAttribute is greater than the lengthAttribute and false if it is equal to
or smaller than lengthAttribute. The BOM line condition will include the BOM
line only if the calculation returns true, whereas the route operation will
only be included if the calculation returns false.
The introduction of the Calculation concept means that an attribute can get its
value set by four different sources:
  • User, value entered by the user during the configuration
  • Default, value set in the product model
  • Calculation, value resulting from a calculation expression
  • Constraint, value set by a constraint
In the matrix below the rows state, which input sources have the ability to overwrite
an existing attribute value. Overwriting a value set by a constraint would result
in a model, which is in contradiction, and thus the configuration cannot be
finished and saved. This is indicated by the * in the Constraint column cells.
So one example here is that a calculation can overwrite a value set by a constraint,
but then the configuration cannot be saved.
Input order matrix
Can be overwritten?
User
Default
Calculation
Constraint
Can
overwrite?
User
Yes
Yes
Yes *
Default
No
Yes
Yes *
Calculation
No
No
Yes *
Constraint
No
No
No
axmfg: Understanding the default configuration concept for constraint-based products Blog bot DAX Blogs 0 17.07.2013 14:11
DynamicsAxSCM: Understanding the product validation process in Dynamics AX 2012 Blog bot DAX Blogs 0 07.12.2012 03:12
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part III Blog bot DAX Blogs 0 17.05.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part II Blog bot DAX Blogs 0 11.05.2011 06:15
Часовой пояс GMT +3, время: 07:18.
