Старый 13.09.2013, 01:12   #1
dynamicscpm: 60 Dynamics AX 2012 attributes available in Management Reporter
Источник: http://blogs.msdn.com/b/dynamicscpm/...ttributes.aspx
By now, with all the blogs post highlighting what you can do with Management Reporter, you are probably ready to take reporting to the next level. More than likely you have read a blog or heard a presentation where we discuss the benefits and flexibility you have with report design when you use attributes.
The following is a list of the 60 attributes you can report with in Management Reporter and Dynamics AX 2012.
In Management Reporter, in either the Row or Column Definition, you will see any of the attributes you have defined. So, for example, if you have never created a reversing entry, you will not see it in your list.
Here are also a few blogs that we have written over the past year or so related to attributes. So go ahead and “design away”! Your next favorite report is waiting!
Attributes overview
Using posting layers
AX 2009 attributes
Audit attributes
Vendor and customer name
msdyncomm: Assigning main account category in Microsoft Dynamics AX with Management Reporter Blog bot DAX Blogs 2 22.08.2013 00:12
axnontechnical: Management Reporter and Microsoft Dynamics AX 2012 R2 Budget Planning Blog bot DAX Blogs 0 23.02.2013 01:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Часовой пояс GMT +3, время: 10:48.
