Старый 18.10.2013, 05:17   #1
25,643 / 848 (80) +++++++
AX Developer tips: Summary update "Invoice account" doesn't work for intercompany sales orders
Источник: http://axdevposts.blogspot.com/2013/...nt-doesnt.html
Hello altogether
I have discovered a strange behavior of AX (AX2012) with regards to intercompany orders and summary update.
Our customer has two subsidiaries and ships packages to the end customers (persons, further customers) in name of its clients (companies, further accounts). Sometimes one subsidiary (I will mention the company name – 101) ships packages to the customers of second subsidiary’s (102) accounts. We create an intercompany direct delivery order for that. Therefore, the whole supply chain looks like this:
SO 101 - PO 102 - SO 102
Intercompany is configured to post packing slip (product receipt) through the whole chain.
Picking is performed once a day and sometimes it comes out, that there are several orders for one customer, which are shipped together in one package. We summarize these orders into one packing slip and consider, that both PO 102 and SO 102 will also have a single delivery document posted (product receipt and packing slip).
Issue 1:
At first we used automatic summary update in both modules (Sales and Purchase):
Doing that we faced some severe performance problems, related to the query, choosing lines for update. There are more than a million customers in each company. Automatic summary update uses a sub table SalesJournalAutoSummary, containing one row per document type, storing update parameters in the customer master and on the sales order, to enable flexible summary of different document types:
The query, created inside the class SalesFormLetterParmData then looks like this:
SELECT FORUPDATE *
FROM SalesParmSubTable(SalesParmSubTable)
ORDER BY SalesTable.InvoiceAccount ASC,
SalesTable.CurrencyCode ASC,
SalesParmSubTable.TableRefId ASC
WHERE ((ParmId = N'101-005992'))
EXISTS JOIN *
FROM SalesParmLine(SalesParmLine)
WHERE SalesParmSubTable.ParmId = SalesParmLine.ParmId AND
SalesParmSubTable.TableRefId = SalesParmLine.TableRefId AND
SalesParmSubTable.OrigSalesId = SalesParmLine.OrigSalesId
JOIN *
FROM SalesTable(SalesTable) ON SalesParmSubTable.OrigSalesId = SalesTable.SalesId
JOIN *
FROM SalesJournalAutoSummary(SalesJournalAutoSummary)
ON SalesTable.AutoSummaryModuleType = SalesJournalAutoSummary.ModuleType AND
(SalesTable.AutoSummaryModuleType == 0) &&
(SalesJournalAutoSummary.CustAccount == SalesTable.CustAccount)
(SalesTable.AutoSummaryModuleType == 1) &&
(SalesJournalAutoSummary.SalesId == SalesTable.SalesId)
) AND ((DocumentStatus = 5))
If you select summary update = “Invoice account”, then this query will look like this:
SELECT FORUPDATE *
EXISTS JOIN *
JOIN *
So it’s the same, but without SalesJournalAutoSummary and its complex range.
Due to the fact, that it is an intercompany direct delivery, we have a double slow down: the query is executed for both companies.
So, if you have a really huge customer master (usual for retail companies), please rethink using automatic summary update
So we gave up an idea to use the automatic summary and switched to a summary by invoice account. In fact, invoice account and currency were the group fields for summary.
Issue 2:
It comes out, that the summary does not work for intercompany orders in case of summary update option “Invoice account”. Funny, but if you choose the option “Automatic” and select only two fields “Invoice account” and “Currency” to summarize by, it works fine! The error is in this code (\Classes\SalesFormletterParmData\reArrangeLines, line 5, follow my comments):
// it’s executed only for non-intercompany orders or
// if summary update is “Automatic” or “Order”.
if (!salesTable.isInterCompanyOrder()
|| salesParmUpdate.SumBy == AccountOrder::Auto
|| salesParmUpdate.SumBy == AccountOrder::Journal)
if (this.createNewJournal(localSalesParmSubTable))
// responsible for storing summary information (is done only once for the first order)
if (!salesParmUpdate.SumSalesId)
salesSummary.summarySalesId (salesTable.SalesId);
salesSummary.summaryTableRef(formletterParmData::getNewTableRefId());
oldSalesParmTable = localSalesParmSubTable.salesParmTable();
if (oldSalesParmTable.RecId && _queryRun.changed(tableNum(SalesParmSubTable)))
salesParmTableReArrange.data(oldSalesParmTable);
if (salesParmTableReArrange.SalesId != salesTable.SalesId)
this.updateParmTable(salesParmTableReArrange, salesTable);
salesParmTableReArrange.TableRefId = salesSummary.summaryTableRef();
this.insertParmTable(salesParmTableReArrange);
else
salesParmTableReArrange.clear();
this.createParmTable(salesTable, null, salesSummary.summaryTableRef(), true);
moveParmLine(localSalesParmSubTable.OrigSalesId, localSalesParmSubTable.TableRefId,
salesSummary.summarySalesId(), salesSummary.summaryTableRef());
localSalesParmSubTable.TableRefId = salesSummary.summaryTableRef();
// this code will be executed in case of intercompany and summary update =
// "Invoice account. There will be no summary
else
This is also true for AX2009 (\Classes\SalesFormLetter\reArrange, line 242)
We haven’t posted any request to Microsoft so far, but we have corrected the “if” statement so that the orders, posted from our customization are also summarized.
I consider the issue to be in place also for normal intercompany purchase (SO 101 - PO 102). It has nothing to do with the direct delivery.
I haven’t found any documentation, stating, that intercompany packing slips cannot be summarized by account, so I suppose it's a bug.
ax-erp: Posting Invoice from Sales order/ Purchase order. Blog bot DAX Blogs 0 06.11.2012 15:11
ax-erp: How to print Performa Sales Invoice? Blog bot DAX Blogs 0 06.11.2012 15:11
Dianne Siebold: Update on the Dynamics AX SDK Team kashperuk DAX Blogs 1 16.10.2007 08:23
Часовой пояс GMT +3, время: 22:53.
