Старый 21.10.2013, 14:11   #1
25,643 / 848 (80) +++++++
emeadaxsupport: Updating index fields while fetching data from the table using the same index can result in the same row being fetched twice
Источник: http://blogs.msdn.com/b/axsupport/ar...hed-twice.aspx
Given:
1)
Consider the following "GM_Real_Test" table and the highlighted index:
2)
Run following code to populate table records:
static void StringInsert_Real(Args _args)
GM_Real_Test operationTable;
int counter, result, row_number;
Random rand;
counter = 1;
row_number = 500;
while <span style="font-size: medium;">(counter
Старый 21.10.2013, 22:45   #2
db is offline
db
Роман Долгополов (RDOL)
393 / 692 (24) +++++++
так вроде давно известный прикол.
и даже здесь проскакивало
простейший job уходит в бесконечный цикл
sql server, ошибка
dynamicscare: Using Power BI to Analyze Your Dynamics AX Data Blog bot DAX Blogs 1 06.10.2013 18:11
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
Часовой пояс GMT +3, время: 21:23.
