Старый 09.12.2013, 00:14   #1
Pawan's Ax blog: Code to connect to an External Database from X++ Code (AX 2012)
Источник: http://pawansaxblog.blogspot.com/201...-database.html
static void theAxapta_ODBCConnection(Args _args)
LoginProperty loginProp;
ODBCConnection conn;
Resultset resultSet, resultSetCount;
Statement statement1;
loginProp = new LoginProperty();
loginProp.setServer('theAxapta');//you can use IP address as well
loginProp.setDatabase('AXDEVDB');
conn = new ODBCConnection(loginProp);
statement1 = conn.createStatement();
resultSet = statement1.executeQuery("SELECT * from CustTable where DATAAREAID = 'CEU'");
while (resultSet.next())
info(resultSet.getString(1));
X++: X++ Arrays Behave Differently in .NET CIL, in Dynamics AX 2012 Blog bot DAX Blogs 0 17.09.2012 23:11
ssmantha: Debugging .NET code called from X++ code in AX 2012 Blog bot DAX Blogs 1 11.11.2011 15:50
ukax: AX 2012 blog posts on the Edge Blog bot DAX Blogs 0 21.06.2011 19:11
Часовой пояс GMT +3, время: 08:42.
