Старый 03.03.2014, 15:11   #1
atinkerersnotebook: Process Multiple Records At Once By Using The Multi-Select Option
Источник: http://atinkerersnotebook.com/2014/0...select-option/
Originally posted on Dynamics AX Tip Of The Day:
A lot of the time you are not just working on one record at a time, you are processing batches of records. For example, you may be releasing multiple orders to picking, confirming multiple purchase orders, or printing multiple order confirmations. Dynamics AX makes this easy as pie to do because a lot of the time, you can use the multiple selection option to choose the records that you want to perform the same action on, and then it will work through them one at a time so that you don’t have to.Say goodbye to being stuck in the Groundhog Day equivalent of single record processing.
View original
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Часовой пояс GMT +3, время: 01:13.
