Старый 12.05.2014, 18:11   #1
atinkerersnotebook: Enable Change Management On Purchase Orders To Track Changes
Источник: http://atinkerersnotebook.com/2014/0...track-changes/
Originally posted on Dynamics AX Tip Of The Day:
If you want to track your Purchase Orders a little more closely, then you may want to turn on the Change Management feature within the Procurement & Sourcing module of Dynamics AX. This gives you the added ability to have workflow approvals on your Purchase Orders, but will also give you the ability to view the old versions of the Purchase Orders and see the differences between the versions.Now you won’t have to play “Sport The Difference” when trying to work out what was updated on the Purchase Order.
View original 461 more words
emeadaxsupport: Purchase order inventory transactions and active change management Blog bot DAX Blogs 0 15.04.2014 20:12
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
Часовой пояс GMT +3, время: 21:36.
