Старый 19.08.2014, 18:11   #1
axaptacorner: In-Place Data upgrade checklist issue in AX 2012 R3 and AX 2012 R2 upgrade
Источник: http://axaptacorner.blogspot.com/201...ist-issue.html
Issue:
We observed this during AX 2012 R2 and AX 2012 R3 data upgrade other than the Launch Data Upgrade stage, a different stage Presynchronization is blocked: instead of showing the ReleaseUpdateCockpit form but the ReleaseUpdateScriptsHistory form pops up unexpectedly.
Solution:
This turned out that back dated rows were recorded into the log table ReleaseUpdateScriptsHistory (ScriptStage=16: Presynchronization; ScriptStage=17: Launch Data Upgrade).
We have dropped the relevant records from the ReleaseUpdateScriptsHistory:
delete from ReleaseUpdateScriptsHistory where ScriptStage in (16,17,18)
After dropping data Presynchronization and launch data upgrade worked properly.
Happy DAXing!!!
axsa: MDM Adapter - Extending Dynamics AX 2012 R3 Master Data Management Blog bot DAX Blogs 0 22.05.2014 03:28
emeadaxsupport: Get started with AX 2012 R3! Blog bot DAX Blogs 0 05.05.2014 09:11
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
daxserver: Master data management in Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 04.03.2014 03:12
DAX: A Shift to Effective Demand Forecasting With Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 16.11.2013 02:13
Часовой пояс GMT +3, время: 20:07.
