Старый 11.11.2014, 23:11   #1
How to convert a wrong date
Источник: http://alexvoy.blogspot.com/2014/11/...rong-date.html
Standard str2date function tries to fix a wrong date. For example, if we got as a parameter fantastic June 31th, it returns us June 30, which can be a bad result for your business case.
There are at least two possible solutions for that.
First, by converting the result back to a string and comparing it with the initial string.
private container cgiValidateDate(str _dateStr)
date retDate = str2Date(_dateStr, #cgiDateFormat);
boolean isOK = true;
str madeDateStr = date2StrUsr(retDate, DateFlags::FormatAll);
if(retDate == dateNull() || _dateStr != madeDateStr)
error(strFmt("Date %1 is incorrect", _dateStr));
isOK = false;
return [isOK, retDate];
Second, by using .Net function tryParse.
date retDate;
utcDateTime retDateTime;
if(!System.DateTime::TryParse(_dateStr, byref retDateTime))
isOK = false;
else
retDate = DateTimeUtil::date(retDateTime);
Happy date converting!
Kurt Hatlevik: How to use dynamic date ranges in RoleCenter Cue’s Blog bot DAX Blogs 0 18.12.2012 09:11
ax-erp: How to extract Date value from a DateTime field Blog bot DAX Blogs 0 11.09.2012 18:11
How to Bulk Convert Leads in Dynamics CRM 4.0 On-Premise Blog bot Dynamics CRM: Blogs 0 12.03.2011 02:16
axStart: How to convert a column in a table to a different type with the same name without losing data. Blog bot DAX Blogs 0 01.02.2008 21:21
Часовой пояс GMT +3, время: 22:06.
